great idea, tell me why it won't work.
PostPosted: Mon May 08, 2006 8:36 pm    Post subject: great idea, tell me why it won't work. Reply with quote
ok. so i have an automatic. i am thus unable to choose my shift points. the only way i can "fool" the tranny into shifting when i want it to is by letting off the gas for a second. the only problem with this is when i stomp it again the tranny will downshift. the generaly accepted way to ramove this feature is to do a bunch of tranny mods i do not fully understand (yet). but what if...
if i remove that cable on my throttle body that tells the tranny to down shift when i floor it will it not downshift when i go WOT?
i know this would not be good for street use, but what an easy mod to do and undo at the track.
somone tell me if this will work.
PostPosted: Mon May 08, 2006 9:07 pm    Post subject: Reply with quote
Uhh... isn't the problem with no shift at WOT only in OD, or is it both? I never use OD when racing before I hit 75ish.
PostPosted: Mon May 08, 2006 9:42 pm    Post subject: Reply with quote
That cable on a 700r4 is NOT a downshift cable.. its a TV cable. TV means throttle valve. It controls the actual line pressure in the transmission. If you leave this disconnected you'll quickly burn up your trans. Even if you should change the radius of its mounting point you'll burn up the trans. I think what you are actually wanting is the vette servo.
PostPosted: Mon May 08, 2006 10:52 pm    Post subject: Reply with quote
the vette servo involves tranny modification, i was trying to find a way to achieve a similar outcome without turning a wrench. so if the TV cable is the Throttle Valve cable, what do you call the cable from the shifter to the tranny? i always thought THAT was the "TV" cable. i had always assumed the Throtle valve cable was just to tell the tranny when do downshift....
well it was a good theory. Very Happy glad i did not just try it to see what happens Shocked
as for the vette servo.. i do not plan on doing ANYTHING to "build up" my TH700R4. i am going to drive it untill
a: it explodes
b: i swap in a 6 or 5 speed. Very Happy
PostPosted: Tue May 09, 2006 7:58 am    Post subject: Reply with quote
Vette servo is just a bolt in piece. Real easy to do.
Even then sometimes it will hang on the shift, you prolly need a good shift kit. That's a little more involved, but the trans does not have to come out to do these mods.
This is the second main reason I don't like 700R4.... 3rd would be that you can't got WOT in OD unless you put a different part in aswell.
PostPosted: Tue May 09, 2006 10:14 am    Post subject: Reply with quote
so you mean when i was doing 95MPH down the track with my foor to the floor i was in third?
PostPosted: Tue May 09, 2006 10:15 am    Post subject: Reply with quote
Yes, you were in third. Count the number of times it shifts.
PostPosted: Tue May 09, 2006 2:43 pm    Post subject: Reply with quote
weak....
PostPosted: Tue May 09, 2006 8:15 pm    Post subject: Reply with quote
Why? If you aren't out of RPM in 3rd, why be in forth? You'll just lose ET and power being in the higher gear. With the 6spd I JUST shift into 4th (your third) before the line.
PostPosted: Tue May 09, 2006 8:27 pm    Post subject: Reply with quote
time for that 4.56 gear set eh Paully?
PostPosted: Tue May 09, 2006 8:29 pm    Post subject: Reply with quote
Maybe. I could use 4.11 I think. That would make 6th at 60 cherry at about 1700ish
PostPosted: Tue May 09, 2006 9:51 pm    Post subject: Reply with quote
my engine stops making power at 4300 doesn't it? my tranny shifts at 5100 when i am WOT.
PostPosted: Tue May 09, 2006 10:19 pm    Post subject: Reply with quote
Actually, for that Bird, you're peaking out at 4400. Shift a little past that. Do you run a stall converter at all, or is it just a stock TH-700?
PostPosted: Wed May 10, 2006 12:41 am    Post subject: Reply with quote
bone stock TH700R4
PostPosted: Wed May 10, 2006 6:30 am    Post subject: Reply with quote
What do you shift at RPM wise? With my steet tires the 4.10's would put me at 6200 RPM and 108 mph. Of course floating the valves at 5500 I was crossing the finish line at 104mph with the clutch in and engine idling. Mad
PostPosted: Wed May 10, 2006 8:09 am    Post subject: Reply with quote
Shifting at 6300
The Drag Radials are 1 inch taller so my rpms dropped a bit. Plus the time to wind out 3rd makes to 4th gear rpms when I trap like 5000 or so
PostPosted: Wed May 10, 2006 10:52 am    Post subject: Reply with quote
Shifting at 6300
Hard to say if it would be worth the money to change to 4.10's. Shrug
I know with my .63 overdrive 5th is a great cruising gear.
PostPosted: Wed May 10, 2006 11:51 am    Post subject: Reply with quote
rjmcgee wrote:
Shifting at 6300
But imagine the possabilities with a .50 Cruising gear Laughing
I don't think I'll change gears with this rear end. Might consider it for a 12 bolt someday.
