kurfbird Member
Posted: Mon Apr 17, 2006 7:57 pm Post subject: v6 distributor in good shape |
Okay my distributor shizzle the bed. Pick up coil is bad. I am looking for a good v6 distributor for my bird. LMK what you have _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Tue Apr 18, 2006 10:55 am Post subject: |
Waiting to get my car back from the mechanic. Car is allegedly not getting any compression from #4. If my engine turns out to have a blown head gasket, compression ring, or sucked a valve, I'll be parting it.
You can have my Distributor for $25 plus shipping, unless you want to pick it up here in Portland. Brand new Rotor and cap are on it. Do you need the EST connector also? _________________
kurfbird Member
Posted: Tue Apr 18, 2006 1:14 pm Post subject: Is this a factory dist |
Is this a factory dist. My car has all the wiring already _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Tue Apr 18, 2006 5:05 pm Post subject: |
yes it is. _________________
kurfbird Member
Posted: Tue Apr 18, 2006 8:34 pm Post subject: I have a line on two. |
I have a line on two. Will let you know if the deals falls through _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
