Annual Expo Center Swap Meet
PostPosted: Sat Apr 08, 2006 2:32 pm    Post subject: Annual Expo Center Swap Meet Reply with quote
anyone go to this so far this year?
went today and found a pretty good buy on a set of complete 882 SBC heads in good shape for $55 for the pair. Thumbs up
PostPosted: Sat Apr 08, 2006 6:45 pm    Post subject: Reply with quote
awww... i totaly need some of those. Sad good buy Thumbs up
PostPosted: Sat Apr 08, 2006 7:04 pm    Post subject: Reply with quote
Brandon and I were there most of the day (at the Expo, not PIR). Brandon found a few things that he was looking for like dash pad, arm rests and steering wheel for the stepside project. He also got some body work hammers. I just picked up a few tools (breaker bars, etc.) that I wanted to have around. Didn't find anything else that I was looking for or that I couldn't live without. Was a good day though.
PostPosted: Sat Apr 08, 2006 7:24 pm    Post subject: Re: Annual Expo Center Swap Meet Reply with quote
I have a set of 993's which are the same heads pretty much that you can have.
PostPosted: Sat Apr 08, 2006 8:32 pm    Post subject: Reply with quote
are they the same heads that are on the L98 stock/ i actualy don't know what all those numbers tacked on to the end mean.. Confused
PostPosted: Sat Apr 08, 2006 10:55 pm    Post subject: Reply with quote
were refering to the last 3 numbers of a 7 digit casting number. I know some desireable ones are the 993's, 455, 494, 461's, 462's and 186 heads. A couple of those have an identifying mark on the front of two bumps. They're typically called "camel hump" heads.
Mine aren't a giant score. They were used on L82 Vette motors in the 70's and early 80's. and have the 1.94/1.50 valves. and the 76cc chamber.
PostPosted: Sat Apr 08, 2006 11:00 pm    Post subject: Re: Annual Expo Center Swap Meet Reply with quote
[quote="rjmcgee"]
I have a set of 993's which are the same heads pretty much that you can have.[/quote]
Saw a couple pairs of those Rod..I went with the 882's because they have a a machined rib in the center. They were least prone to cracking when they went to lighter casting's in the latter 70's.
PostPosted: Sun Apr 09, 2006 7:19 am    Post subject: Reply with quote
Cool, I have always been under the impression that the 882, 993, and 624's are boat anchors. I tried to sell them for $5 when we had a yard sale a couple years ago but couldn't get it done. Laughing
Tony I think the L98 head is 083 but I'm not real sure of that. That's suposed to be a pretty decent head if ported.
PostPosted: Sun Apr 09, 2006 9:49 am    Post subject: Reply with quote
Well I know for a fact 624's are garbage.. I was needing a set for a cheap rebuild went through 6 heads all were cracked through the exhaust seats.
PostPosted: Sun Apr 09, 2006 4:56 pm    Post subject: Reply with quote
I went through the "whole" casting number today and these are the 6 digit ones which means they ARE in fact L82 Vette Heads. The 7 digit ones (3238882) (3932882) are 400ci heads. At least that's what my SBC interchange bible says. I'm thinking these might do well on a 383. With a flattop piston, you might be able to acheive 10:1 compression.
Demon
PostPosted: Sun Apr 09, 2006 7:34 pm    Post subject: Reply with quote
is it still going on?
i need some stainless and coated LS1 LT's Surprised
Soon to be less than stock
PostPosted: Mon Apr 10, 2006 4:42 pm    Post subject: Reply with quote
Ended yesterday.
Was Thursday through Sunday. They have another one in the fall.
Demon
PostPosted: Mon Apr 10, 2006 7:14 pm    Post subject: Reply with quote
Schultzy89GTA wrote:
Ended yesterday.
remind me when it happens... Surprised
