another quick rear end question
PostPosted: Fri Mar 31, 2006 4:29 pm    Post subject: another quick rear end question Reply with quote
i am going to put that posi unit on ebay. is this information correct for a 10 bolt posi unit?
7.625 ring gear
10 Bolt
accepts 26 spline axles.
is there anything else i should say about it? it came out od a 2.73 rear end, but i am only including the ring gear, so that does not matter right?
thanks guys.
PostPosted: Fri Mar 31, 2006 4:33 pm    Post subject: Reply with quote
If it came with 2.73's stock. Make sure to list that this is a "2 Series Carrier".
PostPosted: Fri Mar 31, 2006 5:01 pm    Post subject: Reply with quote
I hate to ask but how much are you wanting for it? Embarassed
PostPosted: Fri Mar 31, 2006 5:06 pm    Post subject: Reply with quote
I thought you were getting an Eaton, rodney?
PostPosted: Fri Mar 31, 2006 5:46 pm    Post subject: Reply with quote
they are going for arount $50 - $100 on ebay. the 3 series ones closer to $150 the 2 series closer to $50. i would sell it to a crewbie for $40. hows that for a deal Smile
PostPosted: Sun Apr 02, 2006 6:07 pm    Post subject: Reply with quote
I need to. But I'm too stoopid to realise that I am too poor to have two hobbies.
AKA I spent about $1000 at a gun show this weekend. Embarassed
I did finally buy a ministarter for it, just haven't had the shop space to bring it in and install it yet. Starter has been shot since right before the dyno gathering.
