rear end
LB985IROC
1995 Chevrolet Camaro Z/28
PostPosted: Tue Mar 21, 2006 12:16 pm    Post subject: rear end Reply with quote
ok so i wanna get a 3.73 gear set for my rear end but im not totally sure which rear end it is other than its a 10 bolt but im not sure what size or splines or whatever little help please Smile
Cadillac of Bellevue
Retail parts sales
vee-six
PostPosted: Tue Mar 21, 2006 12:22 pm    Post subject: Reply with quote
If it is stock from 85, it is a 7.625" 10bolt with 26 spline axles.
PostPosted: Tue Mar 21, 2006 12:24 pm    Post subject: Reply with quote
Axle splines don't matter on the gear set.
Look it up by application and you'll be fine.
Richmond makes great gears, but they are noisy.
PostPosted: Tue Mar 21, 2006 12:25 pm    Post subject: Reply with quote
Yeah, unless he is changing carriers, the spline count won't be an issue.
PostPosted: Tue Mar 21, 2006 3:24 pm    Post subject: Reply with quote
You might see if this rear is still available. If it is, bolt in and go. It's also a disk brake rear.
http://www.cascadecrew.org/phpBB2/viewtopic.php?t=1330&start=0
LB985IROC
PostPosted: Wed Mar 22, 2006 10:09 am    Post subject: Reply with quote
kool il chekc it out have disc brakes aready so direct fit
Retail parts sales
vee-six
