LB985IROC Member
Joined: 09 Feb 2006 Posts: 478 Location: issaquah, wa
1995 Chevrolet Camaro Z/28
Posted: Mon Mar 20, 2006 3:52 pm Post subject: 3.73 |
i want a 3.73 gear set for my iroc _________________ Cadillac of Bellevue
Retail parts sales
| Xophertony wrote: | | vee-six |
kurfbird Member
Posted: Mon Mar 20, 2006 5:22 pm Post subject: Rear end |
I have a 3.42 rear end. LMK if interested _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Mon Mar 20, 2006 8:56 pm Post subject: Re: 3.73 |
| LB985IROC wrote: | | i want a 3.73 gear set for my iroc |
Buy them new man. $150 and you're set.
Otherwise you may get a used set that was wearing improperly... once you put em on they'll continue to wear poorly even if setup right. |
Posted: Mon Apr 10, 2006 5:31 pm Post subject: Re: 3.73 |
| Twilightoptics wrote: | | LB985IROC wrote: | | i want a 3.73 gear set for my iroc |
where at? _________________ 1983 Z-28 5.7 LT1, T56, Headman headers, BW 9 Bolt Posi Disc, WS6 suspension
Last edited by 83Z28BlackBetty on Tue Apr 11, 2006 9:37 am; edited 1 time in total |
PonchoTA Member
Posted: Mon Apr 10, 2006 8:48 pm Post subject: |
I brought my rear (the entire chunk) to Randy's Ring and Pinion on Airport Rd. in Lynnwood. A couple of days later, I had a new posi, new gears, all set up properly, and ready to install for (I think) less than $500.
I HIGHLY recommend them for any kind of work like that! They are awesome!
You can also just buy the gears from them if you'd rather, but for the price, I don't see how you could go wrongwith them doing the whole job.
Unless you are doing some serious bracket racing, I'd stay away from the Richmond gears too, waaaayyyyy noisy. The US Gear set is very good, have much better wear characteristics and are stronger than OEM, and not nearly as noisy.
Good luck! _________________ Paully |
