Posted: Sat Mar 11, 2006 5:09 pm Post subject: Terminal Velocity: PART I |
Posted: Sat Mar 11, 2006 6:08 pm Post subject: |
That be a T56.........did it come out of 4th gen F bod? _________________
Posted: Sat Mar 11, 2006 6:09 pm Post subject: |
Certainly did.
I just can't figure out how to get the shifter into reverse . Is there a trick like pushing down on it or something?
Far right and up is the place. |
Posted: Sat Mar 11, 2006 6:10 pm Post subject: |
Turn the splines on the input shaft a little and see if it goes. _________________
Posted: Sat Mar 11, 2006 6:16 pm Post subject: |
That sensor thing right next to the shifter is the reverse lockout solenoid.
lol
Posted: Sat Mar 11, 2006 7:33 pm Post subject: |
| I was just going to say it has a lock-out noid. IIRC cheezy didn't hook it up, and just uses a good bit of force to shift into reverse. |
Posted: Sat Mar 11, 2006 8:47 pm Post subject: |
Posted: Sun Mar 12, 2006 12:38 am Post subject: |
I <3 t56.
| Dewey316 wrote: | | I was just going to say it has a lock-out noid. IIRC cheezy didn't hook it up, and just uses a good bit of force to shift into reverse. |
I just tapped into the brake light switch. Easy enough.
Get a pro 5.0 and lou's short stick while you're at it.  |
rice B-4 Member
Posted: Sun Mar 12, 2006 9:31 am Post subject: |
| Dewey316 wrote: | | ...just uses a good bit of force... |
Words to live by. _________________ "Horse power is how fast you hit the wall, Torque is how far you take the wall with you."
99 Camaro Z28 LS1 |
z28redline Member
Joined: 21 Jan 2004 Posts: 83 Location: Vancouver, B.C
Posted: Sun Mar 12, 2006 10:27 am Post subject: |
"A bit of force" AKA - using both hands and leaning on it. I would suggest wiring it in if at all possible.
z28redline |
Posted: Sun Mar 12, 2006 12:07 pm Post subject: |
| iansane wrote: | | I just tapped into the brake light switch. Easy enough. |
so you can only go into reverse if the brakes are on? smart.
does this mean ian is less then 3 t56 trannsmissions? i don't get it. _________________ 86' firebird (Junked in 2015). 88' GTA (sold in 2020).
Posted: Sun Mar 12, 2006 12:12 pm Post subject: |
: whispers :
(I think it is a heart )
Posted: Sun Mar 12, 2006 2:08 pm Post subject: |
Posted: Sun Mar 12, 2006 2:11 pm Post subject: |
| why wouldent he just use the heart smiley... <3 <---does not look like a heart |
Posted: Sun Mar 12, 2006 2:21 pm Post subject: |
| Xophertony wrote: | | why wouldent he just use the heart smiley... <3 <---does not look like a heart |
You're right. It looks kind of like boobs in the horizontal position. |
Posted: Sun Mar 12, 2006 2:33 pm Post subject: |
| Twilightoptics wrote: | | Xophertony wrote: | | why wouldent he just use the heart smiley... <3 <---does not look like a heart |
Heh. I'm just glad I'm not the only person who thought that.  |
Posted: Sun Mar 12, 2006 8:53 pm Post subject: |
