1984 Camaro
PostPosted: Wed Feb 15, 2006 1:34 pm    Post subject: 1984 Camaro Reply with quote
No longer parting this car.....
Will consider selling/trading the Z/28 hood for a Coupe/Berlinetta/RS steel hood, that is black in color.
Last edited by Quasi-Traction on Wed Mar 08, 2006 9:59 am; edited 2 times in total
PostPosted: Wed Feb 15, 2006 1:40 pm    Post subject: Reply with quote
how much do you want for the colum? my 2.8 has two bad items in it's colum, a turn signal switch and the wiper delay switch, does everything like that work on yours, and does it have wiper delay?
also, does anyone know if 84 and 86 colums are compatable? and would it be harder to do the entire colum, or take the doner colum apart and swith this stuff out? seems like the whole colum would be easiest. let me know what yall think.
EDIT* if you want to maintain your camaros "roller" status i will gladly give you my messed up colum, that way you can still move it. it works great except for those two switches that are out.
PostPosted: Wed Feb 15, 2006 1:42 pm    Post subject: Reply with quote
No delay on the wiper's Tony, they're 2 speed, W/O cruise. If you're still intrested, $20 for the column.
PostPosted: Wed Feb 15, 2006 1:44 pm    Post subject: Reply with quote
You'll have to re-grease the shaft, if you take the column out and want to put it back in, kind of a PITA, but with a little patience and a friend to hold it from the inside, its about a 20-30 min job. I just did it yesterday (ironically) with a buddy holding the column inside the car in place.
PostPosted: Wed Feb 15, 2006 1:46 pm    Post subject: Reply with quote
Why don't you just swap switches? Take the wheel off, pop the lock mechanism off, and you're pretty much there.
Easier than pulling the whole column IMHO.
PostPosted: Wed Feb 15, 2006 1:49 pm    Post subject: Reply with quote
sounds good to me. they are two speed now (cause it's broken). at least the turn signals will work again, and the two speed knob on your colum will make it look like all is hunkey dorey. do you want my colum to put in? if so we could swap em together. that way we could hold each others colums in place. ( Laughing you know i worded that sentence three different ways and this one was the least dirty)
when could we do this? i get my car out of the detail shop today. it's nice and pretty out today as well.i could probably be ready to roll around 3pm if you do not work today.
Agreed. Once you've taken a GM Tilt column apart and re-assmebled it you pretty much "get it" and since they're all pretty much the same B/T 1969-1986 you can do it on almost any GM car.
PostPosted: Wed Feb 15, 2006 1:52 pm    Post subject: Reply with quote
neat. so does today work for you? if you are near a phone give me a call, 971-645-9359. we are message boarding at a fast enough rate we might as well just talk on the phone.
PostPosted: Wed Feb 15, 2006 1:56 pm    Post subject: Reply with quote
you got a PM tony, and bring your column with you. I'll have yours pulled by the time you get here.
PostPosted: Wed Feb 15, 2006 2:00 pm    Post subject: Reply with quote
i'll be driving mine there... oh and my buddy is on the way to get me, to get the car right now, so i should be on my way sooner then i though Very Happy
PostPosted: Wed Feb 15, 2006 2:03 pm    Post subject: Reply with quote
hey i guess this means we are going to swap ignition keys... wierd.
PostPosted: Wed Feb 15, 2006 5:28 pm    Post subject: Reply with quote
we are all about crazy swaps over at casa de Gambino.
PostPosted: Wed Feb 15, 2006 7:09 pm    Post subject: Reply with quote
Owned!
PostPosted: Wed Feb 15, 2006 7:25 pm    Post subject: Reply with quote
how is that owned? i am disputing this alleged "owned"-edness. Smile
PostPosted: Thu Feb 16, 2006 1:04 am    Post subject: Reply with quote
hey quasi! i thought of a few more things i need.
a lock leaver (the bit that you touch when you unlock the door) for the drivers side. mine is broken, so EVERY TIME i get out of my car i static shock myself. it's rediculous.
do you have an AC heater box still or a non ac one? i need a non ac one. so does asdfga3 (let the bidding war begin:twisted: )
black things that go on the hatch struts. those beauty covers that cover the torx bolts, i need two of them.
PostPosted: Thu Feb 16, 2006 8:14 am    Post subject: Reply with quote
I have the lock lever for my old black drivers door. Do you just need the black plastic cover or do you need the whole rod? Call it Free if you help me with the window and steering column today. I'll give you the rod too. Its no good to me.
PostPosted: Thu Feb 16, 2006 8:21 am    Post subject: Reply with quote
I'd sell you the non AC box, but someone's already laid claim to it. If you wanna pay more than $45 for it, you can have it, but I know you can get one out of U-pull it, and there's one wrecking yard out off 26 towards Sandy that has 3 non-ac camaros, they'll let em go for like $15 each.
PostPosted: Thu Feb 16, 2006 11:23 am    Post subject: Reply with quote
yeah, i'll hit the yards. no not the rod, just the litle BS plastic piece. Smile
PostPosted: Thu Feb 16, 2006 11:26 am    Post subject: Reply with quote
yeah, I got about 4 of those, consider it yours.
PostPosted: Thu Feb 16, 2006 11:28 am    Post subject: Reply with quote
4?! there are only two per car Exclamation Shocked
