starting problems.
DyskoChris83
PostPosted: Mon Feb 06, 2006 4:55 pm    Post subject: starting problems. Reply with quote
i changed my spark plugs out today, ran great for about 10 minutes, allt eh wires are fine, not getting any spark through any fot eh wires. dad says distributor cap might be shot. any other ideas? ( i was sitting at a stop sign and car sputtered like it was out fo gas. and ill post this in wanted area but if anyone has a distributor cap they dont need ill pay for it. thanks for any help
Sellmanb
PostPosted: Mon Feb 06, 2006 5:03 pm    Post subject: Reply with quote
You can see if your dizzy cap and/or rotor are shot very easily.
Take them off, look at the terminals (they will be inside the cap, should be 8 of them on a V8, 6 on a V6, etc) if they look corroded then they are probably in need of replacement, and replace the cap. You will be looking for where the rotor contacts the terminals to see if it's corroded any. If it is, replace that as well.
PostPosted: Mon Feb 06, 2006 7:58 pm    Post subject: Reply with quote
Your roter can also get coroded at the center point where it draws power from the coil.
Also, go back and recheck all your connections, and your wire routing. It's easy to route wires in bad positions, and end up burning them.
DyskoChris83
PostPosted: Mon Feb 06, 2006 10:17 pm    Post subject: Reply with quote
thanks ill go check my cap and wires tomorrow. it was weird though hwo it died out. was runnign fine right before hand.
PostPosted: Mon Feb 06, 2006 10:34 pm    Post subject: Reply with quote
So it wont start at all now? Did you check for spark out of the coil wire itself? Just disconnect from cap and hold near a ground while someone cranks.(i prefer the other way myself Wink )If you have spark at the coil wire but none at the plug wires then you need a cap/rotor. If this is a large cap HEI then you'll have to pull the cap off, leave the wires connected to the cap(not the plug wires) stand back and crank the motor.. You should see lightning/hear snapping of spark. If you have no spark out of the coil or coil wire then you're most likely problem is a dead ignition module.
