Midnight Sun Member
Posted: Tue Feb 10, 2004 7:10 am Post subject: Wont start |
So, my crappy 1982 LeBaron has a brand new battery, brand new alternator, brand new starter, and then a lot of smaller components have been replaced to new.
But... it wont start, except when I jump it.
Is it because it is a POS mitsuibishi engine, or is there something I should be looking for? _________________
Posted: Tue Feb 10, 2004 7:27 am Post subject: |
| does it crank at all when it is not being jumped? |
Midnight Sun Member
Posted: Tue Feb 10, 2004 12:52 pm Post subject: |
Eh... I would have to lean towards no.
It will crank the first time I turn the key, but any another attempt after that, nothing. _________________
Posted: Tue Feb 10, 2004 1:50 pm Post subject: |
| have you checked the charge on the battery? |
Gibby85 Member
Posted: Tue Feb 10, 2004 4:16 pm Post subject: |
Well, GM likes to put their solenoids ON the starters, so I'm assuming with your new starter that you also have a new solenoid?? If not, better check man. _________________
www.cardomain.com/id/gibbys85 |
sllt1776 Member
Posted: Tue Feb 10, 2004 7:24 pm Post subject: |
yea, check/replace the solenoid. perhaps with the voltage of two batteries the solenoid is working but is too worn for just one battery to supply enough volage for it to work. _________________ Yup, I'm a traitor but I miss my 3rd gen.
TecherB Princess B
Posted: Tue Feb 10, 2004 10:12 pm Post subject: |
What is the actual voltage of the battery?
Have you replaced your positive and or negative battery cables?
If you have too much resistance in either the positive or negative circuit your one battery may not have enough voltage to over come the resistance. Also check you connections on both the positive and negative side. Including the battery terminals because if they are loose the circuit is not completed very well causing too much resistance(check for contamination between post and clamp) and not starting except when jumping would be a simptom. |
84transam383 Banned
Posted: Tue Feb 10, 2004 11:20 pm Post subject: |
| TecherB wrote: | What is the actual voltage of the battery?
If you have too much resistance in either the positive or negative circuit your one battery may not have enough voltage to over come the resistance. Also check you connections on both the positive and negative side. Including the battery terminals because if they are loose the circuit is not completed very well causing too much resistance(check for contamination between post and clamp) and not starting except when jumping would be a simptom. | i was like,NO WAY in hell did bart type this ,until i saw the following
just messin with yua dude  |
90RSrocks Member
Joined: 10 Jan 2004 Posts: 421 Location: Klamath Falls, Oregon
Posted: Wed Feb 11, 2004 1:53 am Post subject: |
No kidding there! With the correct spelling, and even some punctuation, I never realized who posted until you pointed it out! Oh, and Bart you know we wouldn't give ya a hard time if we didn't like ya (and if ya didn't make it so easy)  |
Midnight Sun Member
Posted: Wed Feb 11, 2004 2:52 pm Post subject: |
Whooo hoo.
It was just a defective battery. Replaced free of charge. _________________
