		| Author | Message |
		| mrpopo573 Member
				|  Posted: Sun Oct 30, 2005 10:22 am    Post subject: I have gears???? |   |
				| So, it has come to my attention, after consulting with a fellow third gen buddy, that I am running way higher rpms than him at the same speed.
 So...I did the calculations on thirdgen and they said I have somewhere around 3.42s
 At 60 with 16inch tires I am doing 2000 rpms if not a tiny bit more.
 Does that sound like 3.42s? I can't believe I didn't even notice this.
 Any performance gain???
 I feel like a
  	  | 305302eater wrote: |  	  | Man I would love a 69. I hate you so much.
 2000 Maxima SE 5 Speed VQ30
		| Back to top |  |
				|  Posted: Sun Oct 30, 2005 10:27 am    Post subject: |   |
				| Um... 16" tires? You mean 16" wheels? What is the tire diameter? Which gear are you in, I assume OD?
 Measure the tire DIA and check it in your 1-1 gear. (3rd Auto, 4th manual)
 Doesn't sound all that high to me. But then again I run 3200rpm at 60mph, so everything seems lower!
 If you still have the RPO code list in your center console, you can look up the codes, I believe the G codes show your type of rear and gear.
		| Back to top |  |
		| Dewey316 The Lama
 1990  Chevrolet  Camaro RS
				|  Posted: Sun Oct 30, 2005 10:34 am    Post subject: |   |
				| Thirdgen- tachs are also knowing for being VERY inaccurate.  Do you have an aftermarket tach?  If not when we eventualy do some datalogging, we will see the actualy RPM's. |  |
		| Back to top |  |
		| mrpopo573 Member
				|  Posted: Sun Oct 30, 2005 12:36 pm    Post subject: |   |
				| I know the tach isnt a VDO like accurate one, but I've run this car side by side with an exact same setup and I am turning more rpms. My torque convertor is locking up so that isn't it.
 My bad, yes 16 inch wheels. I will go around and drive the thing in D and see what I turn out.
 It feels more like my GTA did than my friends camaro with 273's
 Oh, well, thanks for the input guys...I'll do some more intelligent checking and get back to yah
		| Back to top |  |
		| mrpopo573 Member
				|  Posted: Sun Oct 30, 2005 4:30 pm    Post subject: |   |
				| Ok, so I couldn't get on it around town, BUT...at 30 mph I am turning 1750 RPMS in 3rd. (Drive)
 What more info should I get guys?
 Thanks again for your help
		| Back to top |  |
		| rjmcgee The Hammer
				|  Posted: Sun Oct 30, 2005 5:13 pm    Post subject: |   |
				| Asuming a 13" tire radius this would give you 4.51 gears.
 Kinda doubt that. If your gears have been changed then your speedo may be off to. Between the speedo maybe being off and the unreliability of these stock tachs everything your doing here is a guess. Pulling the cover and looking for the numbers stamped in the ring gear may be your only option to know for sure.
		| Back to top |  |
		| mrpopo573 Member
				|  Posted: Mon Oct 31, 2005 7:02 am    Post subject: |   |
				| Ok, thanks guys. I'll just pretend I have gears for now so that my signature can be longer.
  Thanks again  _________________
		| Back to top |  |
		| Fastspec2 New Member
				|  Posted: Mon Oct 31, 2005 7:39 am    Post subject: |   |
				| Jack up the back of the car. In neutral mark the driveshaft in 1 place. starting with the mark at the bottom, mark 1 tire at the botton. rotate the driveshaft and count how many times it turns to get the tire mark back to were you started at the bottom having made 1 full rotation. this is the gear ratio. so 3 full turns and almost another half is 3.42. This will only work on cars with a posi. |  |
		| Back to top |  |
				|  Posted: Mon Oct 31, 2005 7:52 am    Post subject: |   |
				|  	  | Fastspec2 wrote: |  	  | Jack up the back of the car. In neutral mark the driveshaft in 1 place. starting with the mark at the bottom, mark 1 tire at the botton. rotate the driveshaft and count how many times it turns to get the tire mark back to were you started at the bottom having made 1 full rotation. this is the gear ratio. so 3 full turns and almost another half is 3.42. This will only work on cars with a posi. |
 You can do this on cars without a posi. I forget the exact formula. Jack ONE tire off the ground. Do the same. That one tire spins twice as fast. So you'll need to take the revs from the tire, and divide by two. So if you had 3.42, you'd see something like 3 driveline revolutions to 20.5 tire rotations.
		| Back to top |  |
				|  Posted: Tue Nov 01, 2005 10:08 am    Post subject: |   |
				| To get the ratio right you need to know the ratio of the side to spider gears, in witch case you would probably know the gear ratio already. |  |
		| Back to top |  |
		| mrpopo573 Member
				|  Posted: Tue Nov 01, 2005 10:32 am    Post subject: |   |
				| I will just wait until I swap my motor and put in the eaton posi diff and then I'll inspect.
 From what i can tell, this car does not feel like 2.73s.
 But thats just gut and butt dyno guessing.
 I appreciate all the expertise guys.
		| Back to top |  |
		| iansane Member
 1991  Pontiac  Trans Am
				|  Posted: Tue Nov 01, 2005 7:16 pm    Post subject: |   |
				|  	  | mrpopo573 wrote: |  	  | I will just wait until I swap my motor and put in the eaton posi diff and then I'll inspect.
 When was the last time you changed the diff fluid? Take the opportunity; change the fluid count the teeth and find out.
		| Back to top |  |
