chip burning
scott in wa.
1988 Chevrolet Camaro IROC-Z
PostPosted: Tue Oct 04, 2005 9:45 am    Post subject: chip burning Reply with quote
Well, have been thinking about buying the stuff to burn our own chips.
Doesn't seem to be that bad in price.????????
There are many different systems out there.
We have a 1987 z28 with auto. has the 305 chip in it, put a built 350 in.
What would be the best way to go to burn our own?
does it matter what computer we have in the car when looking at chip burning equipment?
I have been reading and searching thirdgen.org.
Anybody here have any recommendations???
thanks
Scott
PostPosted: Tue Oct 04, 2005 10:04 am    Post subject: Reply with quote
Moates. He has everything you will need.
scott in wa.
PostPosted: Tue Oct 04, 2005 10:12 am    Post subject: Moates?? Reply with quote
where can I get this?
do you use this?
Thats great, But I was hoping for a little more info.
then again maybe thats all that needs to be said.?
thanks
scott
PostPosted: Tue Oct 04, 2005 10:17 am    Post subject: Reply with quote
http://www.moates.net/ has equipment to get burned chips into the car
http://xtronics.com/memory/EPROM.htm if you want to burn them yourself.
http://www.thirdgen.org/newdesign/tech/promintro.shtml Intro to prom's 101 by Traxion. Read this. Take notes. When you think you know it, read it again.
PostPosted: Tue Oct 04, 2005 10:18 am    Post subject: Reply with quote
You can't just have someone burn you a chip. It either needs to be done on a dyno, or driving around watching what's going on and when. Then you also need an adapter to put a burned chip in. I don't think anyone around here does it old school by erasing your old one and burning to it.
PostPosted: Tue Oct 04, 2005 10:19 am    Post subject: Reply with quote
Moates.net sells the Burn1 burner, it is cheaper than the Xtronics version, and will do the job just as well.
Once you have all the equipment, you are more than welcome to get us to help.
You can also catch me on AIM or MSN in the evening, it would be easier to explain this all in a conversation in that form, vs. posting on a message board.
PostPosted: Tue Oct 04, 2005 10:27 am    Post subject: Reply with quote
Never heard of the burn1 burner. Does it work through USB?
PostPosted: Tue Oct 04, 2005 10:34 am    Post subject: Reply with quote
SWEET IT DOES! NOW I CAN DITCH THAT POS NEC LAPTOP! WOOT!
Wonder if I can get $85 out of my PPII?
PostPosted: Tue Oct 04, 2005 10:35 am    Post subject: Reply with quote
Yes it does. And its only $85
http://www.moates.net/product_info.php?cPath=24_46&products_id=48
PostPosted: Thu Oct 06, 2005 5:13 pm    Post subject: Reply with quote
I have a 87 iroc that was a 305 car it has a 350 in it now runs ok but i burned a chip with mine it runs alot better but remember to adj your fuel presure reg. when you replace the 305 injectors with the 350 ones.
