Help Passing DEQ
Goto page Previous  1, 2, 3
PostPosted: Fri Jun 27, 2014 11:47 am    Post subject: Reply with quote
And I had better emssions than a Prius at a stop light.
PostPosted: Fri Jun 27, 2014 3:04 pm    Post subject: Reply with quote
Crew,
I sold G33kSqu4d the catalytic converter off of my 86 firebird. It looked fine, I could still see through all the honeycomb, but is it possible i sold him a dud converter?
G33K5QU4D
1983 Chevrolet Camaro
PostPosted: Fri Jun 27, 2014 3:21 pm    Post subject: Reply with quote
OK guys, I finally passed, with everything being well below the allowed. Not sure why all the fluctuation, but I got my new tags and everything! Thanks guys for all the help.
1983 Camaro
PostPosted: Fri Jun 27, 2014 3:22 pm    Post subject: Reply with quote
How many miles were on that cat? the newer they are the better they work.
No real way to tell they dont work by looking at them..
PostPosted: Fri Jun 27, 2014 3:51 pm    Post subject: Reply with quote
50K or less probably.
PostPosted: Fri Jun 27, 2014 4:04 pm    Post subject: Reply with quote
Glad you finally passed.
The cat has a precious metal coating. If that coating is gone from contamination like coolant, oil, fuel, etc it can look fine, but not make the reaction. The only way to tell is get the car HOT and check with a temp gun. Should be approx. 100deg hotter on the outlet, than the inlet.
PostPosted: Fri Jun 27, 2014 4:17 pm    Post subject: Reply with quote
When you passed, did you get to test right away or did you sit in line for a while?
G33K5QU4D
PostPosted: Fri Jun 27, 2014 4:19 pm    Post subject: Reply with quote
Was probably about 4 cars back, probably sat in line for about 15-20 mins.
1983 Camaro
PostPosted: Mon Jun 30, 2014 8:58 pm    Post subject: Reply with quote
Glad you passed. FYI, the calibration on some of their machines is pretty wacko, even though they're supposed to be checked and recalibrated every 3 months or so, I seriously doubt that's kept on schedule.
Page 3 of 3
