Posted: Mon Dec 02, 2013 2:58 pm Post subject: |
Specific to the rocker and lifter and hole in the head. _________________ A redline a day keeps the carbon away! |
Posted: Mon Dec 02, 2013 3:36 pm Post subject: |
I believe pushrod diameter is determined by the heads and rockers.
One thing to keep in mind is that you should use the same brand of pushrod checker and pushrods to ensure you get the actual correct length. _________________ 84 Camaro Z28 - LS1/T56
fiveoformula Member
Posted: Mon Dec 02, 2013 3:37 pm Post subject: |
| Well im running stock roller lifters, and the holes in the head have not been modified. |
fiveoformula Member
Posted: Mon Dec 02, 2013 3:40 pm Post subject: |
| Alphius wrote: | I believe pushrod diameter is determined by the heads and rockers.
One thing to keep in mind is that you should use the same brand of pushrod checker and pushrods to ensure you get the actual correct length. |
I ordered a comp cams pushrod checker so I was planning on getting comp pushrods. My rocker arms are jegs alluminum pieces, cam is Lunati, lifters are GM... lol |
fiveoformula Member
Posted: Wed Dec 04, 2013 1:26 pm Post subject: |
Pushrods ordered!
Let's talk clutches, which one do you guys have and what do like/not like about it? And how much did you pay?
I had a stock replacement one off the shelf at a parts store before and honestly it seemed to work fine, aside from my hydraulic issues I had for so long. |
Posted: Wed Dec 04, 2013 1:28 pm Post subject: |
| I have a centerforce DF, it holds fine at the power levels I'm at, and has lasted a lot of miles. I honestly have no complaints, but someone like Paul who has ran several different ones might have a better comparison to some of the stuff like the different stages from Spec vs CF and the others. |
Posted: Wed Dec 04, 2013 8:06 pm Post subject: |
| That little smallblock will not be able to do anything to an off-the-shelf clutch IMHO. I'd leave it in there if it's not worn or glazed. |
fiveoformula Member
Posted: Wed Dec 04, 2013 10:19 pm Post subject: |
| The disc is getting close to the rivets. Trust me id put it back in if it was worth putting back in, I'm trying to spend my dollars wisely. |
fiveoformula Member
Posted: Mon Dec 16, 2013 12:03 am Post subject: |
Well I'm going to have to change my name from fiveoformula to five7formula!
The old bird lives! Went for about a 30 minute drive tonight, runs pretty decent even without a tune! I have poly motor mounts now and the spohn torque arm, first impresions of that are awesome! Also ended up going with a ZOOM clutch and wow, to my surprise pedal effort is even easier than my old "off the shelf" schucks/o'reilly clutch. Feeling pretty good about everything, oil pressure is nice, I may have set the base timing a little high as it struggled a little to start after it was warm, but for now, just going to break it in nice but not too nice, then tune it and work out a few more details like getting some braided fuel hose and I need a new oil dipstick tube.
Thank you guys for all the helpful advice! _________________
'88 FORMULA |
Posted: Mon Dec 16, 2013 7:37 am Post subject: |
Don't baby it. You need good load and decel to seat the rings. _________________ A redline a day keeps the carbon away! |
fiveoformula Member
Posted: Mon Dec 16, 2013 9:40 am Post subject: |
Definitetly, I was downshifting it every chance I get. Havent floored it, but driving like an @$$hole basically.  |
Posted: Mon Dec 16, 2013 9:55 am Post subject: |
I had a Zoom clutch on my HSR 350 as well, it did nicely for the time I had it. _________________ 84 Camaro Z28 - LS1/T56
fiveoformula Member
Posted: Mon Dec 16, 2013 10:01 am Post subject: |
| So far I really like the feel of it, its the "kevlar" one, trying to figure out why my last clutch felt so heavy. |
Posted: Mon Dec 16, 2013 7:02 pm Post subject: |
| just out of curiousity, do Roller tappet cams require the same "break-in" that flat tappets do? |
Posted: Mon Dec 16, 2013 7:09 pm Post subject: |
No real breakin for rollers.
D- your oem clutch was stiff because the pressure plate was doing the holding. The kevlar clutch gets its grab from the material so they can ease up the pressureplate pressure. Be careful and don't slip kevlar much. If you glaze it its done. _________________ A redline a day keeps the carbon away! |
fiveoformula Member
Posted: Mon Dec 16, 2013 11:34 pm Post subject: |
I will keep that in mind, thanks.
This clutch came with a warning to break it in with 700 "in town" miles before giving it full throttle, is it easy to glaze over when new? |
Posted: Tue Dec 17, 2013 3:22 pm Post subject: |
Full throttle is ok as long as the clutch is engaged. Its slipping under power you want to avoid. Easier to glaze when its still developing a wear pattern _________________ A redline a day keeps the carbon away! |
Posted: Wed Dec 18, 2013 2:11 pm Post subject: |
Did you ever calculate what your compression ratio is? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
fiveoformula Member
Posted: Wed Dec 18, 2013 7:37 pm Post subject: |
Pics!
So.. I am actually worried about hood clearance now that it just dawned on me the engine probably sits higher than the 305 did with these new mounts....
And I still have ugly bent up stock fuel lines, will get some braided lines soon. _________________
'88 FORMULA |
fiveoformula Member
Posted: Sun May 25, 2014 4:02 pm Post subject: |
Some of you may have already heard.. 3500 miles on that kevlar zoom clutch and it slips like crazy all the sudden. Ive put tons of miles on other clutches and never had one act like this.
Pretty irritated with it.
Now ill probably order a centerforce dual friction and that just takes money away from other things I was going to do to the car..... ARG... end rant* |
