Posted: Mon Jul 29, 2013 6:43 pm Post subject: |
Seals and or guides. And a WB for tuning. :O) _________________ A redline a day keeps the carbon away! |
BluFbdy Member
Posted: Mon Jul 29, 2013 7:11 pm Post subject: |
Wb is in the works, my buddie Donnie just got an aem sponsorship for the drift car and we have multiple cars under their system lol time for new heads and maybe a cam if I'm feeling groggy, might as well do it how I want now that its not my daily haha _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Tue Jul 30, 2013 8:03 am Post subject: |
If that was mine I'd just run it. How much oil does it consume? It doesn't look bad at all in the video. Not bad enough to waste a ton of money simply to fix it. If you want more performance and have some mods that just happen to include fixing it, then go right ahead. I had a set of freshly rebuilt heads that smoked worse than that after 5k miles of being on the road. I burned like a quart of oil every 2,500-3,000 miles. I eventually fixed it by swapping on some aluminum heads.
Stop worrying and go do brodies, continue on with the tuning because you will pick up some power. Rebuild heads for a little oil consumption? Nah, not worth it. If you're eating a ton of oil, then it is probably worth it. _________________ 84 Camaro Z28 - LS1/T56
fiveoformula Member
Posted: Tue Jul 30, 2013 8:24 am Post subject: |
I wish mine only smoked that much... but 180k piston rings on a 305 don't really hold the oil back revving to 6k. lol _________________
'88 FORMULA |
Posted: Tue Jul 30, 2013 9:32 am Post subject: |
Yeah, yours smokes a bit buddy. Still makes good power though.  _________________ 84 Camaro Z28 - LS1/T56
fiveoformula Member
Posted: Tue Jul 30, 2013 12:07 pm Post subject: |
I love driving in front of hybrids, we can put it that way.  |
91camaro_rs Member
Posted: Sat Aug 03, 2013 7:06 pm Post subject: |
andy our bottom ends were put together by the same dude, mine only leaks through the timing cover gasket. i burn oil on startup and thats pretty much it. it might be heads but i say just run it _________________
