DIY retrofit AC 134a
PostPosted: Sat Aug 13, 2005 6:16 pm    Post subject: DIY retrofit AC 134a Reply with quote
This article explains what you need to do step by step from begining to end on retro fit your ac system with the 134a. the guy uses a corvette as an example. So the componants are very similar to the f-body. http://www.diynet.com/diy/shows_wkm/episode/0,2046,DIY_14348_26868,00.html
