Posted: Wed Jun 05, 2013 6:25 am Post subject: |
pfff, J-85 only has about 3,000 lbs of thrust. Go bigger.  |
flea Member
Posted: Wed Jun 05, 2013 6:56 am Post subject: |
You see. Even when I'm going big, I'm on a budget _________________ Killing mailboxes since 2009 |
Posted: Wed Jun 05, 2013 8:17 am Post subject: |
Most everything has been done before. Hes poor like the rest of us. Det is the best cheapest route. _________________ A redline a day keeps the carbon away! |
flea Member
Posted: Wed Jun 05, 2013 12:07 pm Post subject: |
V8 is fun to think about. Jet engines are just cool, but this will probably get 6 cyl cause it is almost a straight swap. No need to worry about fenders, tranny tunnels, steering boxes, steering linkages, crappy light weight front suspension or any of that.
JY 6 and T5, off the shelf install kit, couple body panels a trip to el cheapo paint shop and she's on cl. _________________ Killing mailboxes since 2009 |
Posted: Wed Jun 05, 2013 12:08 pm Post subject: |
| Twilightoptics wrote: | | Most everything has been done before |
Cummins swap  |
Posted: Wed Jun 05, 2013 4:36 pm Post subject: |
| Brings back chevette memories.. |
91camaro_rs Member
Posted: Thu Jun 06, 2013 6:11 pm Post subject: |
flea if your interested my buddy has a 2.8/T5 for sale, he wants $500 _________________
Posted: Thu Jun 06, 2013 6:55 pm Post subject: |
Is that with harness/ECU and accessories? _________________ 84 Camaro Z28 - LS1/T56
91camaro_rs Member
Posted: Thu Jun 06, 2013 7:01 pm Post subject: |
yeah, only problem is i think the harness might be a little damaged _________________
Posted: Thu Jun 06, 2013 7:11 pm Post subject: |
| Damaged how? |
91camaro_rs Member
Posted: Thu Jun 06, 2013 8:32 pm Post subject: |
i think there is like 3 missing pigtails _________________
flea Member
Posted: Thu Jun 06, 2013 10:23 pm Post subject: |
I need to pull some panels and look for hidden rust before I make a solid decision as to what to do.
There are certain places that like to rust from the inside out on these cars, unfortunately there isn't really any good way to know without some disassembly. I will start that this weekend. _________________ Killing mailboxes since 2009 |
Posted: Fri Jun 07, 2013 9:02 am Post subject: |
$500?!?!?!?! The engine better be brand new and the newer less rod knock prone vintage!! _________________ A redline a day keeps the carbon away! |
