Tired of cheap crap.
Goto page Previous  1, 2
PostPosted: Mon May 06, 2013 11:45 am    Post subject: Reply with quote
Obsolescence. Portland napa warehouse doesn't stock the alternator at all. Seattle stocks one. Portland doesn't stock the ps pump either. Again Seattle has one. The ps pressure hose. There are 3 in the country apparently. Nearest in Sacramento
PostPosted: Mon May 06, 2013 12:32 pm    Post subject: Reply with quote
I have a thirdgen PS pressure hose I can send you for the cost of the flat rate box. Brand new. Never been used. It was for my car before I dropped the LS1 in.
PostPosted: Mon May 06, 2013 4:26 pm    Post subject: Reply with quote
Will probably be different since mine is V-belt. Have it on the way anyway.
PostPosted: Mon May 06, 2013 4:34 pm    Post subject: Reply with quote
No problem. Very Happy I've been trying to get rid of some garage clutter. Mine was v-belt as well. I had the '87 multi-rib alternator and v-belt PS pump setup on my 350. Originally the setup was in an '87 Trans Am.
PostPosted: Mon May 06, 2013 4:42 pm    Post subject: Reply with quote
Ah.. so would have worked .. same set up.. Might hang on to it, looks like it's going to be rare! LOL
PostPosted: Mon May 06, 2013 5:17 pm    Post subject: Reply with quote
I may still need that power steering pump if you still have it. Very Happy
PostPosted: Mon May 06, 2013 5:22 pm    Post subject: Reply with quote
I am pretty sure I do. Very Happy
PostPosted: Sat May 11, 2013 2:04 pm    Post subject: Reply with quote
Got everything fixed up. Not crazy about the new ps pump though. The shaft has more slop in it then the original did. It was definately the pump that went out though and not the hose. Seal started leaking.
Moved the fan switch from that crazy place in the head. Put it in the thermostat housing. Figure the thermostat needs to be open before the fan comes on anyway.. now I won't be melting the wiring anymore.
Page 2 of 2
