Posted: Mon Jan 21, 2013 6:34 am Post subject: 99 Malibu questions |
So helping a mommy of 3 out by fixing her car.
It has the 3.1 "m" code engine. Idling rough, compression test showed 70 in cyl 1, while rest were 110-115. I am getting lots of steam that smells like exhaust back thru the radiator. Getting lots of water(no coolant smell) from the exhaust.
Whats confusing me, is the spark plug had no rust. No coolant smell from exhaust. Does the converter clean that up, or does it burn away from the heat and just leave steam/water? _________________ 2008 GMC Z71
Posted: Mon Jan 21, 2013 7:18 am Post subject: |
Also trying to figure out the difference between the head gasket sets. There are 3.
hst9957pt-2
his9957pt-2
hs9957pt-2 |
Posted: Tue Jan 22, 2013 7:40 pm Post subject: |
Water is a natural byproduct of combustion, so seeing some in the exhaust is normal. I'd be looking at that #1 cyl. _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Wed Jan 23, 2013 6:23 am Post subject: |
I'm talking this thing had so much water in less then 5 minutes, it looked like I spilt 2 gallons of water under the back end of the car.
I got it apart last night. Whats effed up is the gasket was cracked on 3, and thats what was getting fluid. However, you could see exhaust blowby going over to cyl 1
However, 4 of the 6 cyls had cracks in the heads between the valves. One was also cracked to the spark plug hole. |
kurfbird Member
Posted: Wed Jan 23, 2013 7:00 am Post subject: OOO that bad |
I think Malibu were notorious for this. Intake gaskets leaking. _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Wed Jan 23, 2013 7:17 am Post subject: |
All fwd 3100/3400's were known for intake gaskets. Which had already been done on this car.
This one, the heater core went out, she kept driving it and it over heated. But I think the head gasket was on its way out already by the looks of the gasket. The over heating just finished it off.
Oh, I never did find the drain plug on the radiator either.  |
Posted: Wed Jan 23, 2013 8:35 am Post subject: |
GM had a crapload of coolant gasket failures in that era. A combination of the poorly engineered plastic gaskets and the poorly engineered DexCool.
Jay, it sounds like this car's headed for China unless you can find another late 60* for scrap price. |
Posted: Wed Jan 23, 2013 9:32 am Post subject: |
Uh dexcool is badass man..... _________________ A redline a day keeps the carbon away! |
Posted: Wed Jan 23, 2013 11:02 am Post subject: |
Dex is great until it gets old. It needs changed on schedule. _________________ 84 Camaro Z28 - LS1/T56
Posted: Wed Jan 23, 2013 1:17 pm Post subject: |
The problem is that they billed it as a "lifetime" coolant and then sold all those cars to women.  |
Posted: Wed Jan 23, 2013 2:32 pm Post subject: |
It is lifetime. When the engine dies it's lifetime is over. _________________ 84 Camaro Z28 - LS1/T56
Posted: Wed Jan 23, 2013 2:44 pm Post subject: |
I dont remember seeing anything other than extended life. I dont run green in anything I own. Check the freeZing point annually and is good is good is goooood. _________________ A redline a day keeps the carbon away! |
Posted: Wed Jan 23, 2013 2:48 pm Post subject: |
| Alphius wrote: | | It is lifetime. When the engine dies it's lifetime is over. |
Quiet, you.
When I bought the Monterey it had a reprint of the Ford dealer service manual for the '62 Thunderbird in the trunk. In the Ford literature they touted both lifetime antifreeze and a lifetime maintenance free battery.
| Twilightoptics wrote: | | I dont remember seeing anything other than extended life. |
IIRC they only ever guaranteed it for 150K. Problem was that the acid they added to get it to last ate the o-rings and and plastic gaskets. Then there were the people stupid enough to actually believe it would last 150K.
| Twilightoptics wrote: | | I dont run green in anything I own. |
Bavarian blue in the Bimmer, Fleetguard Final Charge SCA red in the knocker. Green is for beater commuters. Dexcool is for flushing out.  |
Posted: Wed Jan 23, 2013 3:30 pm Post subject: |
I run cheap green stuff and change it every year or two.
I do electrolysis and acidity tests as well. This method has never done me wrong.  _________________ 84 Camaro Z28 - LS1/T56
Posted: Wed Jan 23, 2013 6:11 pm Post subject: |
| aaron_sK wrote: | | Bavarian blue in the Bimmer, Fleetguard Final Charge SCA red |
Cliffs on final charge? We've stocked that for awhile and I've never sold any of it because I don't know what to recommend it for... _________________
Posted: Wed Jan 23, 2013 6:41 pm Post subject: |
| aaron_sK wrote: | | Jay, it sounds like this car's headed for China unless you can find another late 60* for scrap price. |
Yea, she doesnt have the money to fix it. I have some mechanic friends that like to flip cars, so I'm talking to them. I'm debating myself, but I have to many projects as is to spread my money across. |
Posted: Wed Jan 23, 2013 7:22 pm Post subject: |
| iansane wrote: | | Cliffs on final charge? We've stocked that for awhile and I've never sold any of it because I don't know what to recommend it for... |
Saves diesel guys from having to buy bottles of SCA's and test strips and fiddling with that BS all the time. They claim 3 years, 6K hours or 300K before you have to add their "extender" and then it's good for another three years.
Sell it to diesel guys. Especially guys with the IDI 7.3 or the 7.3 Strokes, those seem to get the block worm worse than other engines. |
