Strange intake manifold gasket issue:
PostPosted: Thu Jan 03, 2013 6:33 pm    Post subject: Strange intake manifold gasket issue: Reply with quote
I've been fighting an idle issue in the mazda - random changes to AFR, engine tries to die at stop lights.
I did the old carb clean around the intake trick and seemed to find the primary ports leaking vacuum. Replaced the gasket and surfaced the intake manifold and they still leaked. Straight end showed some inconsistencies on the block but the gasket was much thicker than the offset. So I tried it with a new gasket and some anaerobic sealant and still when I spray some carb clean and the gasket gets wet, it exhibits a leak.
I found some threads about people saying when this gasket gets wet it leaks vacuum. WTF? Anyone hear anything like this? I'll have to bring my propane torch home and try it without dampening the gasket I guess.
Damn I need to find $$ for the megasquirt! lol
PostPosted: Thu Jan 03, 2013 7:26 pm    Post subject: Reply with quote
Seems to me if paper gets wet it should be less likely to allow a vacuum through it.
How about using some gasket paper? Is the pattern too complex to reliably cut out?
PostPosted: Thu Jan 03, 2013 7:39 pm    Post subject: Reply with quote
As Aaron said, that seems bass ackwards. Usually adding a liquid to a gasket causes it to swell and then seal not the other way.
PostPosted: Thu Jan 03, 2013 8:23 pm    Post subject: Reply with quote
This is a crazy weird material I'll tell you that.
Could make another one.... but I've got this can of copper coat.....
PostPosted: Thu Jan 03, 2013 8:35 pm    Post subject: Reply with quote
What isn't crazy weird on a wankel? Laughing
PostPosted: Thu Jan 03, 2013 9:58 pm    Post subject: Reply with quote
PostPosted: Thu Jan 03, 2013 10:16 pm    Post subject: Reply with quote
Time warp? Shocked
PostPosted: Tue Jan 15, 2013 5:38 pm    Post subject: Reply with quote
Seems to be sealed now. Carb still leans out when coming to a stop. Damnit, need money for MS!
PostPosted: Tue Jan 15, 2013 8:00 pm    Post subject: Reply with quote
Come build me an exhaust. Wink
