cars been fishy since i got it back
91camaro_rs
PostPosted: Sun Dec 09, 2012 3:49 am    Post subject: cars been fishy since i got it back Reply with quote
so since i got my car back from ABC transmission i noticed that at idle the afr doesn't like to be at 14.7 anymore it sits at about 12.8-13.5 and there is also a sound thats not a tick but not a knock its like inbetween, i checked for exhaust leaks and there is none, and it doesnt sound like the click of a loose rocker arm. is there anything in the tranny that could cause this or could it be something more internal, also listening to the exhaust at the tail pipe it steady and every 4 seconds or so it has a big puff come out, im not sure if thats how its supposed to be cause i only have resonators or what but it doesnt seem normal
PostPosted: Sun Dec 09, 2012 10:11 am    Post subject: Reply with quote
Loose flex plate bolts or cracked flexplate will make that kind of noise. Does the noise change when its shifted between drive and neutral?
PostPosted: Sun Dec 09, 2012 11:22 am    Post subject: Reply with quote
But a bad flex plate won't make it run rich. Razz
Did they drop the exhaust to R&R the trans?
PostPosted: Sun Dec 09, 2012 11:34 am    Post subject: Reply with quote
Who says there's only one problem? Oh and what will happen if the knock sensor picks up this noise? hmm?
91camaro_rs
PostPosted: Sun Dec 09, 2012 10:42 pm    Post subject: Reply with quote
turns out they moved the spark plug wire for cylinder 8....the wire was super melted and the noise was the wire arching to the header....threw on a temporary wire and ordered a new set, im suprised it didnt throw a code...
what are the best wire looms to use? i got the MSD Street Fire 5570's same ones i have now
PostPosted: Mon Dec 10, 2012 7:18 am    Post subject: Reply with quote
Haha thats what I wss going to suggest looking at. My 85 hsd the driverside wires under the header. Same issue wuth Msd wires after visiting the transmission shop. Msd wiees are junk anyway they get hard way too fast.
PostPosted: Mon Dec 10, 2012 8:18 am    Post subject: Reply with quote
You've gotta slow down on that phone keyboard, Paul. Razz
FWIW I use Taylor wires and I like the Taylor 42700 looms.
I have run that setup on many cars and have never had an issue.
91camaro_rs
PostPosted: Mon Dec 10, 2012 11:23 am    Post subject: Reply with quote
phone keyboard Laughing Laughing
91camaro_rs
PostPosted: Mon Dec 10, 2012 12:22 pm    Post subject: Reply with quote
did you run your wires under or over the headers?
PostPosted: Mon Dec 10, 2012 1:13 pm    Post subject: Reply with quote
Embarassed
It was early and I was in the "office"
I'll do better next time. Its a new phone too.
PostPosted: Mon Dec 10, 2012 2:45 pm    Post subject: Reply with quote
Depends on the engine and the headers. On an SBC with shorties I would go up.
PostPosted: Mon Dec 10, 2012 5:14 pm    Post subject: Reply with quote
From the top down through the headers in pairs.
AKA 1/3 and 5/7 together.
91camaro_rs
PostPosted: Mon Dec 10, 2012 11:02 pm    Post subject: Reply with quote
the driver side is fine, its the passenger side thats always causing problems number 8 is just a pain to get to ill figure it out haha
PostPosted: Wed Dec 12, 2012 4:47 pm    Post subject: Reply with quote
You must have Flowtech or Edelbrock headers then. Wink
If you loom six and eight together as Paul suggested and then run them up behind that annoying crossover primary tube you should be fine.
BTW, in the future you should buy universal plug wires so you can get the lengths correct.
91camaro_rs
PostPosted: Thu Dec 13, 2012 10:54 am    Post subject: Reply with quote
yeah flowtech haha
PostPosted: Thu Dec 13, 2012 8:41 pm    Post subject: Reply with quote
I run my wires under the headers. I use zip ties to keep them tight to the block. Haven't had an issue.
91camaro_rs
PostPosted: Sat Dec 15, 2012 1:02 am    Post subject: Reply with quote
i got my new wires so when i get some free time ill route em up and clean it up
