truck opinions
Goto page Previous  1, 2, 3, 4, 5
jchaussee
PostPosted: Sun Sep 30, 2012 7:05 pm    Post subject: Reply with quote
My poor camaro getting no love cause of truck. For truck I will need to do glow plugs and suspension. for Camaro I suppose i will get heads cleaned and worked if they haven't been sitting to long. And then hopefully during winter I will take out motor and give it a little bit more power. Truck is basically stereo and seats after I get before mentioned items taken care of. I may do black rims also
jchaussee
PostPosted: Fri Oct 05, 2012 7:49 am    Post subject: Reply with quote
So wierd, but totally related issue. Hopefully somebody knows the answer. So as discussed before, I need to check glow plugs because of the no start when colder. But also, what I have noticed is that when it doesn't start even after it does start, my heater fan won't turn on for a while. Probably takes 20 min of driving. Any ideas?
PostPosted: Fri Oct 05, 2012 10:27 am    Post subject: Reply with quote
Sticky relay?
Actually both of those problems could be caused by relay failure.
jchaussee
PostPosted: Fri Oct 05, 2012 11:10 am    Post subject: Reply with quote
Glow plug relay?if that's case that's a litrl easier
IROCDave
PostPosted: Fri Oct 05, 2012 6:29 pm    Post subject: Reply with quote
Somehow I feel we've had this debate on here before. Laughing
IROCDave wrote:
Superduty has been living on reputation since the late 90's
The truck in question is a '99. Last really good year for the SD.
In my experience the new Duty's break and break expensively. All Duras break, usually in the front end or fuel system as was already mentioned. Also they get worse economy than any other diesel made over the past three decades.
The biggest problem I have with the Duramax is the stigma that goes along with it. Every time you see one it's some halfway retired old dude towing his boat, or an engineer who wants to look cool in front of the crew, or some foreman. Truthfully I can only recall one guy I have ever seen who actually put his Dura to work.
Sorry for pissing in the pool, and yes this discussion has happened before. Carry on.
PostPosted: Fri Oct 05, 2012 7:14 pm    Post subject: Reply with quote
It's the Crew way buddy! Laughing
PostPosted: Fri Oct 05, 2012 7:47 pm    Post subject: Reply with quote
We need some of that stuff that changes the water color lol
jchaussee
PostPosted: Fri Oct 05, 2012 7:56 pm    Post subject: Reply with quote
Better then poopin in the pool
IROCDave
PostPosted: Fri Oct 05, 2012 8:00 pm    Post subject: Reply with quote
Lol, just felt bad about diving in and pollututing a legit post. However the debate isnt dead..just need a dedicated thread. Keep the Ford fix suggestions cummins Very Happy
PostPosted: Sat Oct 06, 2012 7:20 am    Post subject: Reply with quote
Laughing That's a good one.
PostPosted: Sat Oct 06, 2012 7:24 am    Post subject: Reply with quote
Before a CATastrophic failure occurs. Wink
PostPosted: Sat Oct 06, 2012 10:18 am    Post subject: Reply with quote
... and causes an International incident.
jchaussee
PostPosted: Tue Oct 23, 2012 4:14 pm    Post subject: Reply with quote
Well shoot. Wasn't blower motor relay.
jchaussee
PostPosted: Thu Oct 25, 2012 3:04 pm    Post subject: Reply with quote
Well fixed blower motor kindof. Tapped it with a rubber mallet and it came on.
Page 5 of 5
