Posted: Tue Sep 25, 2012 11:30 am Post subject: |
| Dewey316 wrote: | | I wonder if it was setup with no IAC control, and if the iac passage is completly blocked and the butterfly completely closed, i could see it needing a hole that large to idle. |
Possibly, but if they had done that why would they have left that chrome idle solenoid hanging off the side of the TB?
Very strange choices were made by someone. |
Posted: Tue Sep 25, 2012 3:27 pm Post subject: |
| aaron_sK wrote: | | Dewey316 wrote: | | I wonder if it was setup with no IAC control, and if the iac passage is completly blocked and the butterfly completely closed, i could see it needing a hole that large to idle. |
Maybe to keep the hole filled, but they didn't have an ECM able to control it. |
Posted: Tue Sep 25, 2012 8:25 pm Post subject: |
| Dewey316 wrote: | | Maybe to keep the hole filled, but they didn't have an ECM able to control it. |
If it's an Indmar motor the ECM they use has IAC control. _________________
Posted: Tue Sep 25, 2012 9:45 pm Post subject: |
I've drilled two holes summing close to that size in a holley. My hsr and 58mm tb I put a longer throttle stop screw in rather than drilling, but it was long.
Besides, big hole, more closed throttle body.
In fact, I bet someone ran two breathers and no pcv. _________________ A redline a day keeps the carbon away! |
Posted: Sat Sep 29, 2012 4:17 pm Post subject: |
| DBL_TKE wrote: | | RSFreak wrote: | Stealth Ram is better for less money.  |
Cost aside, how do you figure the HSR is "better?" |
Conventinal wisdom from those who have tried both (I almost hate to say this, but search TGO) . The bigger plennum and longer runners would seem to be the most obvious reasons to me. The HSR also looks better, IMHO.  |
Posted: Sun Sep 30, 2012 8:31 pm Post subject: |
Oh I have been searching. There wasn't too much, if any, info regarding comparisons. I still can't find anything about the plenum volume though. I have found someone who claimed to have flow tested one to 276CFM@28". And I found that the runner length is 5.75" long. And I also found this Dyno graph comparing a vortec headed TPI to a vortec/ramjet, same cam.
