oldsmobile blues...
Goto page Previous  1, 2
PostPosted: Sat Aug 25, 2012 12:47 pm    Post subject: Reply with quote
fiveoformula wrote:
That sounds cool, was the motor from a TransAm or some big oldsmobile? Was it quick?
Not sure what it came from, but was the same as what was in a lot of the Trans Ams, some motor homes, etc. Wasn't near as quick as I would have liked for the size motor (was stock and only had 180 HP from factory), still had the V6 trans and rear end. I think my Camaro 305 would have outdone the 403 as far as quickness...
PostPosted: Sat Aug 25, 2012 1:24 pm    Post subject: Reply with quote
Now put a motorhome behind both the 403 and the 305 and race them again! Wink
The 403 was a stump puller. With the right gearing and driver it is a good motor, but if you apply traditional muscle car logic to it (low gearing, light weight, high rpm) it's a dog.
PostPosted: Sat Aug 25, 2012 3:31 pm    Post subject: Reply with quote
Which is odd because the 403 is a giant bore short stroke motor. 4.351" bore.. largest ever in a sb v/8 with a 3.385 stroke.
Sounds good for a revver.. except the olds oiling system isnt up to the task. Only good for 5k rpm. Also the 403 had window'd mains so the crank had a habit of breaking right off the bottom of the block. It's rumored that some motor homes got non window'd mains, but nobody's ever proved it with a picture.
That said dad's 79 TA seemed to move quite well with one.
PostPosted: Sun Aug 26, 2012 10:49 pm    Post subject: Reply with quote
So if you had a TransAm with a 403, do they do better with some super tall gears or something?
PostPosted: Mon Aug 27, 2012 6:30 am    Post subject: Reply with quote
Alot of them were delivered with rear end ratio's in the 2.4x range. 2.73 and 3.23 would have been performance ratio's.
Page 2 of 2
