Posted: Fri Jul 13, 2012 10:14 am Post subject: |
I think its 4:10 or 4:11, single gear axle.
Then I think it has the 4l80 transmission. |
Posted: Fri Jul 13, 2012 2:36 pm Post subject: |
| You have a little better overdrive than I do (.75 vs my .80) but the same axle ratio. Your tires look a little shorter than my 33's so I'd bet that aside from the converter we're probably running the same RPM's at the same speeds. |
Posted: Sat Jul 14, 2012 3:36 am Post subject: |
| tires are 245/70 or 75/16, so yes they are smaller then 33's |
