Advice or opinions
Goto page Previous  1, 2
PostPosted: Wed Jun 06, 2012 11:09 pm    Post subject: Reply with quote
Wait, I thought the 5.3L tahoe motor was a LS? Just iron block?
PostPosted: Wed Jun 06, 2012 11:37 pm    Post subject: Reply with quote
It's LS based but LS1/2/3/4/6/7/9 are just the codes for the motor. The 5.3 truck engine is most commonly LM7 (what I have). Also could be L33, L59, LH6 and a host of other ones depending on year, iron/alum, flex fuel capable, DOD/AFM/VVT, etc.
PostPosted: Thu Jun 07, 2012 6:11 am    Post subject: Reply with quote
Sounds like you've had too much TGO, Paul! Razz Laughing
They share the same design, and some parts will physically interchange, but they share no actual components and the dimensions are wrong (4.8 and 5.3 are smaller bore). Guys like Ian who do the swap are basically building an LM/LS hybrid. That's why I said all he would be buying is the longblock.
BTW, you got PM, Paul.
jchaussee
PostPosted: Thu Jun 07, 2012 1:49 pm    Post subject: Reply with quote
I offered,him 150. If he says yes ill buy it.
jchaussee
PostPosted: Thu Jun 07, 2012 5:53 pm    Post subject: Reply with quote
Jon. When you,say 5k is that just engine and accesories ? Or is that other associated items?
PostPosted: Thu Jun 07, 2012 6:41 pm    Post subject: Reply with quote
That's to get the car driving.
PostPosted: Fri Jun 08, 2012 8:33 pm    Post subject: Reply with quote
I thought I would toss in that the ECM software is not cheap either. It was running $200 for a license, don't know what it costs now adays. I would also agree with Jon that a 4L60E will be far more consistant and equally fun to drive. Plus you can tune it and run flappy paddles (if you're into that kind of thing).
jchaussee
PostPosted: Fri Jun 08, 2012 8:56 pm    Post subject: Reply with quote
I have been looking at,autos now more cause I may want to turbo it later. The softwarei was looking at was about 400 or so. But well worth it for futire upgrades. Also,if you,use painless wiring kit they will flash ecm for free.
PostPosted: Fri Jun 08, 2012 9:05 pm    Post subject: Reply with quote
Painless Wiring is one of the highest cost rip-off options you can find. A stock engine harness and fuse center is better.
If you want a cheap tune that's close enough then do a mail order tune from Texas Speed. Painless doesn't know jack crap about custom tuning. I bet they just put a stock tune on it, and every ECM you get will have a stock tune already.
jchaussee
PostPosted: Fri Jun 08, 2012 9:24 pm    Post subject: Reply with quote
I heard you got to have it flashed first to get rid of all the anti theft crap and stuff like that. Also on I side note ill be in f town tomorow.
PostPosted: Fri Jun 08, 2012 10:05 pm    Post subject: Reply with quote
I can vouch for Painless being anything but painless. Granted, all the wires are there, but the install is very PAINFUL. The harness I had a hand in doing was for a carbureted motor, so should have been easy, but nooo.
PostPosted: Fri Jun 08, 2012 10:13 pm    Post subject: Reply with quote
Third-ed.
Painless is garbage. Very overpriced, quality lacking, any semblance of logical design lacking as well. Modify the stock stuff or build your own.
Back on topic: If you have a stock ECM then you can do the HPTuners jazz for around $400, or go MegaSquirt for about the same price if you don't.
jchaussee
PostPosted: Fri Jun 08, 2012 10:26 pm    Post subject: Reply with quote
Id like megasquirt but dont kniw if I am smart enougj
PostPosted: Fri Jun 08, 2012 10:38 pm    Post subject: Reply with quote
No offense but if you don't feel you're smart enough to get an MS setup going then you're probably not going to be able to modify a stock harness, get it properly installed in the car, and then tune the factory ECM with HPTuner.
jchaussee
PostPosted: Fri Jun 08, 2012 10:39 pm    Post subject: Reply with quote
I can tune a ecm. I cant build one.
PostPosted: Fri Jun 08, 2012 10:52 pm    Post subject: Reply with quote
Buy it built from DIYEFI.
jchaussee
PostPosted: Fri Jun 08, 2012 10:56 pm    Post subject: Reply with quote
Ya. I've been looking. One thing though that appealed to me while reading gabes thread was the do everything yourself aspect. I may give it a shot.
PostPosted: Sat Jun 09, 2012 8:33 pm    Post subject: Reply with quote
The factory PCM is really good and has all the safety features and diagnostics built in. I wouldn't built a Mega Squirt unless that's your idea of fun.
Page 2 of 2
