Yard watch, 305tpi, t5, 2 pbr rears, and a 91 or 92 bird
redlava
PostPosted: Sun Apr 29, 2012 5:26 am    Post subject: Yard watch, 305tpi, t5, 2 pbr rears, and a 91 or 92 bird Reply with quote
I was at this new junkyard (horseshoe auto wrecking) off belfair highway looking for a tow hitch for the dakota. Of course, i had to check for camaro parts. There was a 88 trans am with what looked like a complete 305tpi, mated to a t5 and a 10 bolt with pbrs (possibly out of a 4th gen should be a 9 bolt for this year). This car also had the trans am tail lights. There was forth gen auto z28(lt1) with a complete rear. I did not check for the engine. There was a 91 or 92 bird with those pieces that go between the front wheel and the front nose. The pass side one was in good shape, the drives side had a small crack about an inch long (looked like it could be repaired).
There were probably 6 third gens that weren't really picked over at all. In fact none of the cars there had really been touched. Seemed like they had good prices.
BluFbdy
PostPosted: Sun Apr 29, 2012 4:44 pm    Post subject: Reply with quote
thats right around the corner from my house...i feel retarded for not looking there lol looks like im going to go there before work tomorrow and take a peek
1987_sportcoupe
1987 Chevrolet Camaro
PostPosted: Mon Apr 30, 2012 5:04 pm    Post subject: Reply with quote
While you're there can you find out how much they want for the T5?
BluFbdy
PostPosted: Mon Apr 30, 2012 5:30 pm    Post subject: Reply with quote
If I'm nor mistaken he said its a fourth gen t5
PostPosted: Mon Apr 30, 2012 5:43 pm    Post subject: Reply with quote
Reading comprehension! Razz
He thinks the axle is a fourth-gen, not the transmission.
BluFbdy
PostPosted: Mon Apr 30, 2012 11:14 pm    Post subject: Reply with quote
If I'm .
redlava
PostPosted: Tue May 01, 2012 7:35 am    Post subject: Reply with quote
There are no V8 T5's in a 4th gen, only t56. The rear axle in the third gen is possibly from a 4th gen becuase it has the pbr rear brakes and a 10 bolt not stock for that car.
PostPosted: Tue May 01, 2012 8:17 am    Post subject: Re: Yard watch, 305tpi, t5, 2 pbr rears, and a 91 or 92 bird Reply with quote
4th gen V6 t5s have a ford bolt pattern for the 3800 motor.
1987_sportcoupe
PostPosted: Tue May 01, 2012 6:30 pm    Post subject: Reply with quote
Well I'm gonna go pick up that tranny either Friday or this weekend. I wonder if they can pull it for me and make my life easier? Hmmm
PostPosted: Tue May 01, 2012 7:06 pm    Post subject: Reply with quote
Don't let yard monkeys pull your stuff! They'll leave good parts on the car, bolts won't get saved, things will get broken/stripped/whatever. Do it yourself, do it right. Cool
PostPosted: Tue May 01, 2012 9:17 pm    Post subject: Reply with quote
I'm with stupid
Particularly the part about bolts not getting saved! You NEED those bolts! Wink
redlava
PostPosted: Wed May 02, 2012 10:57 am    Post subject: Reply with quote
I would call before hand, about how to go about the removal of the tranny. Alot of the cars there still had the wheels and tires attached including the trans am with the t5. The cars are not elevated on the T-welded rims.
BluFbdy
PostPosted: Fri May 04, 2012 9:01 am    Post subject: Reply with quote
I'm on my way down there right now I need a mirror and those dang plastic clips for he hatch plastics, maybe snag a few good extra parts idk
BluFbdy
PostPosted: Fri May 04, 2012 10:14 am    Post subject: Reply with quote
That old guy at the counter is an extreme prick. They've got 2 great dash pads there though
PostPosted: Fri May 04, 2012 10:28 am    Post subject: Reply with quote
...that's the wrecking yard that I gave my '87 formula shell to.
BluFbdy
PostPosted: Fri May 04, 2012 10:41 am    Post subject: Reply with quote
It wouldn't have been black with rims would it? he was just a dick to me for no apparent reason, really enjoys snapping at people apparently.
PostPosted: Fri May 04, 2012 8:25 pm    Post subject: Reply with quote
No, red. However, this was probably a decade ago?
