Carb & emissions
Goto page Previous  1, 2
PostPosted: Fri Feb 24, 2012 10:53 am    Post subject: Reply with quote
I have never needed more than one bottle because I run the tank down to maybe a gallon or two left. Plus you can buy it at any corner auto store. Wink
PostPosted: Fri Feb 24, 2012 5:38 pm    Post subject: Reply with quote
Yeah I'll have to try some additive I suppose, this car had been sitting for years. Does anyone think I should mess with the carb?
'88 FORMULA
PostPosted: Fri Feb 24, 2012 5:59 pm    Post subject: Reply with quote
I've got an idea there may be a problem having a carb'd car idle so fast for the test. I know with fuel injection people bump the idle up to clean up emissions, but on a carb if you open the butterflies too far you'll step out of the idle jets and start opening up the main circuit. This would cause your hc's to rise.
Anyone else think this could be a problem?
PostPosted: Fri Feb 24, 2012 6:07 pm    Post subject: Reply with quote
Could be. He'd had to look and see if it's opened past the idle circuit.
PostPosted: Sun Feb 26, 2012 10:01 pm    Post subject: Reply with quote
It has burned up this tank of fuel pretty dang quick, and that might explain the high HC's. maybe I'll try setting the idle around 700ish. I may try some seafoam thru the vacuum lines and a couple bottles of iso-heet in the tank. If that doesn't work I'll have to get more potent.
Page 2 of 2
