Posted: Thu Feb 09, 2012 8:02 am Post subject: |
| Jay I've seen that kind of thing happen to nearly-new tires due to potholes or road debris. Anything that causes the belts to separate will end up like that. |
Posted: Thu Feb 09, 2012 8:16 am Post subject: |
We had it happen on a few new tires, but they were the cheap ass ones. I mostly saw it on old ones.
But none the less, it causes vibrations |
Posted: Thu Feb 09, 2012 8:52 am Post subject: |
Okay, I see what you mean now. I was envisioning little air bubbles, not a rupture. |
91camaro_rs Member
Posted: Thu Feb 09, 2012 11:23 pm Post subject: |
the bolt that i had going through the mount was a little short so i could see how the nut could have fallen off, but i replaced it with a longer one _________________
Posted: Fri Feb 10, 2012 6:28 am Post subject: |
| You need to get the correct graded bolts and locking nuts in there or it will continue to be an issue. |
