HID kits
Goto page Previous  1, 2
PostPosted: Thu Feb 09, 2012 1:36 pm    Post subject: Reply with quote
I come across projector housings all the time. They are for big rigs, but I could keep a few of them if you guys want to dissect them. They use a HB3 2 wire style bulb, but are clearly projection lenses.
4x6 projector housings? I'd definitely be interested. I plan on doing an FX-R projector retrofit sometime this year. I've been going back and forth about whether I want to do it into 4x6 housing or E36 housings.
PostPosted: Thu Feb 09, 2012 1:48 pm    Post subject: Reply with quote
Alphius wrote:
I was under the distinct impression that halogen projectors (which my Impreza had factory) were different than actual HID projectors.
This supports my case. The differences are small, but they will lead to a non-optimal light pattern.
http://www.hidplanet.com/forums/showthread.php?16902-HID-Projector-vs.-Halogen-Projector-differences&s=0e526b6b56d23dab207ad19637d7ac02&p=161287&viewfull=1#post161287
At this point I feel I'm being pretty pedantic though. Laughing I'm really nitpicking but I just want to make sure I have all my ducks in a row on this. I'm sure you understand.
Oh I realize they're "different" but it's kind of the same way factory 'vette L98s and fbody L98s differ. Their output varies SLIGHTLY, the construction varies a bit in some places but their function is almost identical. HID projectors are just nice because then you can use and off the shelf D2S/D2R/D4R/D1R/D1S/whatever capsule.
Dibs! Laughing
I'm pretty sure he just means the projectors themselves. Not a retro setup.
PostPosted: Thu Feb 09, 2012 2:01 pm    Post subject: Reply with quote
Agreed. Just for the sake of clarity and correct information.
You've got me seriously considering the benefits of HIDs on the Subie.
PostPosted: Thu Feb 09, 2012 2:08 pm    Post subject: Reply with quote
They are molded to the hood housings. Not even close to 4x6.
I'm sure you could fab the projector into an e-code housing.
PostPosted: Thu Feb 09, 2012 2:27 pm    Post subject: Reply with quote
Paul, if you get a chance I'd love to get a couple of those from you and play around with them.
Are they just discarded and replaced at your work or something?
PostPosted: Thu Feb 09, 2012 2:31 pm    Post subject: Reply with quote
Yeah. Usually they get replaced from accidents or the common yellow fog of the outer lens.
I'll grab some the next time I see some through. Usually get a few every month.
jchaussee
PostPosted: Thu Feb 09, 2012 2:46 pm    Post subject: Reply with quote
Well if anybody wants to go the cheap route with me, I am sure if there are a few of us I could get him down to 150 for all four lights
Page 2 of 2
