Posted: Sun Jan 29, 2012 11:59 am Post subject: |
| Alphius wrote: | | The Jeep one is from a mid-late 90's Grand Cherokee, right? |
NO. Early (80's - mid 90's) Cherokee is what you'd be looking for. Not a Grand Cherokee. Most of the Grand Cherokees have a steering shaft that has a smaller diameter joint that slips onto the upper steering column shaft, therefore will not fit. The regular Cherokees fit like charm. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Fri Feb 03, 2012 2:46 pm Post subject: |
Ok, just went to the yard. Beat on one for over an hour. Still didnt get it out.
How the Eff do them things colpase(sp?) to remove them? |
Posted: Fri Feb 03, 2012 3:35 pm Post subject: |
The Square Cherokee's before the mid 90's switch uses the exact same Saginaw steering column as the thirdgen.
When I say ExAcT.... I mean I used parts from a spare thirdgen one to get an '87 Cherokee column back in shape. _________________ A redline a day keeps the carbon away! |
Posted: Fri Feb 03, 2012 6:54 pm Post subject: |
| 91RSVert wrote: | Ok, just went to the yard. Beat on one for over an hour. Still didnt get it out.
Lots of PB blaster and a pry bar. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
algershick Member
Posted: Fri Feb 03, 2012 11:08 pm Post subject: |
I've read also that some Astro intermediate shafts are different lengths than others. I pulled one today from Budget Auto Wrecking in Auburn for $25. It came out of a '98 AWD Astro van and appears to be long enough to fit without lengthening. The upper u-joint is definitely going to require re-clocking. _________________ 1988 GTA, 5.3/T56 in the works. |
