my turbo camaro
PostPosted: Wed Feb 01, 2012 8:03 pm    Post subject: my turbo camaro Reply with quote
warming it before i stored it.
http://www.youtube.com/watch?v=DY23BBpO3qg
PostPosted: Wed Feb 01, 2012 8:12 pm    Post subject: Reply with quote
i dyno'd last fall and had a bov leak so i couldn't get it above 10 p.s.i.
so my max hp is 387.68hp and 497.62 of torque. i need to get it back up to 500 hp but using a different cam and carb. my timing is locked out at 23 degrees may need to go 30.
http://www.youtube.com/watch?v=y9VmaceBl6o
PostPosted: Wed Feb 01, 2012 8:16 pm    Post subject: Reply with quote
Anything internal done to the motor? It seems awfully lean at almost 13:1 for my liking on a boosted vehicle. Razz
Good run though.
PostPosted: Wed Feb 01, 2012 8:37 pm    Post subject: Reply with quote
well marty at stomberger performance says im spot on if i go any richer i'll foul out my plugs at idle. Had a spare 350 out of a 1970 camaro and had the engine rebuilt at cassell engines. I have the stock forged crank, scat forged I rods and dished ICON forged pistons with chrome molys. i also i have 441 heads rebuilt with 2.02 valves ported and polished. the combustion chambers were so uneven cc'd the heads and had 72 to 75 cc so made them all 75.5 cc chambers. also using a turbo cam that marty is using in his 7 sec TT trans am.
my old engine had the forged parts except for the pistons which were speed pro hypers' and had the 993 heads( which are more desirable gm stock heads to work with) 2.02 valves ported and polished. also a stock cam that cam with the block.
PostPosted: Wed Feb 01, 2012 10:12 pm    Post subject: Reply with quote
Man, that thing must rip tires loose all day long! Smile
Is it the cam holding you back or do you just need to uncork that thing with more air flow? (in other words, will a cam help much?)
PostPosted: Wed Feb 01, 2012 11:55 pm    Post subject: Reply with quote
im not sure i went with a turbo cam with a least amount of valve overlap but still using the 1.6 roller rockers on both exhaust and intake. i did downsize the carb to a 650 from my 750. but i did replace the bov and fixed the leaks.
And yes i lay down good rubber doing 35 mph while dragging the brakes. can cant help it on wet pavement.
i also got a GoPro camera so ill be videoing it for your viewing pleasure.
IROCDave
PostPosted: Fri Feb 03, 2012 5:01 pm    Post subject: Reply with quote
Nice sleeper. You got a leaky ignition system though. I can hear spark arc in the vid.
IROCDave
PostPosted: Fri Feb 03, 2012 5:05 pm    Post subject: Reply with quote
The arc sound starts at the 1:07 mark.
PostPosted: Sat Feb 04, 2012 12:47 am    Post subject: Reply with quote
yeah i've been having problems with that notice the different color wires there i'm unable to run a wire loom there and the pipes are hard to avoid on that side. i need to find some long socks to put on the wires. and get some header wrap for the cross over pipe as its close to the charge pipe.
PostPosted: Mon Feb 06, 2012 3:24 pm    Post subject: Reply with quote
here is a vid of my car driving around.
http://www.youtube.com/watch?v=bHpEzUomLTs
http://www.youtube.com/watch?v=dlm2Hx1r0EQ
PostPosted: Mon Feb 06, 2012 3:32 pm    Post subject: Reply with quote
Sorry for the rattle. Im using a go pro hero hd suction cupped to my t-top. I am thinking about getting a roll cage mount for the go pro.
