Posted: Wed Dec 14, 2011 4:56 pm Post subject: Let the fun begin.............. |
Well, after a year of collecting, mostly the past 3 months, its time.........
[/img] _________________ 2008 GMC Z71
Posted: Wed Dec 14, 2011 5:55 pm Post subject: |
Miller time?
Hammer time?
Paradoxical time?
Man of the year Time? |
Posted: Thu Dec 15, 2011 7:57 am Post subject: |
time for a new bump stick and some goodies to go with it.
After this, I will basically have a zz4 with tpi injection.  |
Posted: Thu Dec 15, 2011 7:09 pm Post subject: |
izcain 9sec Club
Posted: Fri Dec 16, 2011 8:54 am Post subject: |
It's always fun to get that timing cover to seal back up without taking the pan off!  _________________
9.17 @ 148 |
IROCDave Member
Posted: Fri Dec 16, 2011 4:33 pm Post subject: |
| Floor jack, bottle jack, busted knuckles, BFH, bent coolant lines, lots of swearring and yet it will still leak oil when done. Lots o fun. |
Posted: Fri Dec 16, 2011 5:22 pm Post subject: |
| IROCDave wrote: | | Floor jack, bottle jack, busted knuckles, BFH, bent coolant lines, lots of swearring and yet it will still leak oil when done. Lots o fun. |
Posted: Fri Dec 16, 2011 6:08 pm Post subject: |
Yea, started jacking the car up tonight.
No coolant lines to bend  |
Posted: Sat Dec 17, 2011 11:25 am Post subject: |
Slowly getting there. Did end up taking the pan off.
:edit: oil pan back on, back on motor mounts, WP and pully on, radator back on, fans on, rocker studs tightened, rockers on. Intake welded, ground, and cleaned.
Crank pully ended up coming back off
Still need to put exhaust and starter back on. |
Posted: Mon Dec 19, 2011 11:42 am Post subject: |
Getting exciting!  _________________
Posted: Mon Dec 19, 2011 8:00 pm Post subject: |
On hold here tell Wed night.
BTW, can people see my pics since there from FB and nobody could see my video?
Posted: Mon Dec 19, 2011 8:07 pm Post subject: |
Pictures show up for me. _________________ A redline a day keeps the carbon away! |
Posted: Mon Dec 19, 2011 8:22 pm Post subject: |
And me. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
izcain 9sec Club
Posted: Mon Dec 19, 2011 9:21 pm Post subject: |
same here pics look fine! _________________
9.17 @ 148 |
Posted: Wed Dec 21, 2011 3:31 pm Post subject: |
Got it together, go to start it for the first time get some loud clacking and no fire. Second try, no noise, but no start.
Posted: Wed Dec 21, 2011 4:09 pm Post subject: |
Sounds like timing or Cam timing.
Did you degree the cam or just install it straight up? Did you turn the engine over 1 full rotation before installing the distributor? _________________ A redline a day keeps the carbon away! |
Posted: Wed Dec 21, 2011 4:31 pm Post subject: |
The chain only had one notch, so no degreeing it.
Um, cant remember on dizzy. I'm starting to think maybe half way.
:edit: more I think, I stabbed the dizzy on #4. crap! |
Posted: Wed Dec 21, 2011 4:57 pm Post subject: |
When you line up the timing gear marks to put the chain on, you are TDC of #1 exhaust stroke. So you need to rotate the motor 1 full turn lining the timing pointer up, then stab the dizzy on #1. _________________ A redline a day keeps the carbon away! |
Posted: Wed Dec 21, 2011 5:36 pm Post subject: |
I took it apart with mark up, mark up, dizzy on 1.
But I had to rotate the motor to set the rockers, and I did that before I put the intake on and dizzy. Didnt rotate it back. UGH.
Still doesnt explain noises. |
Posted: Wed Dec 21, 2011 5:58 pm Post subject: |
yIIKES.
Never put the chain on mark up mark up.
The marks are there to point at each other and make sure you didn't run it a tooth off.
Noises could be a number of things. Valve adjust, Timing, Lifters that haven't seen oil yet. _________________ A redline a day keeps the carbon away! |
