Valvetrain questions
Goto page Previous  1, 2
PostPosted: Tue Nov 15, 2011 5:56 pm    Post subject: Reply with quote
gut what? Wink
I can tell the car revs better w/o it on. So I know its a choke, just cant come up with any good ideas.
PostPosted: Tue Nov 15, 2011 6:52 pm    Post subject: Reply with quote
Personal question: Is a stock dual snorkel with the base cut and clean filters good enough for a higher-revving-than-TPI StealthRam? Razz
PostPosted: Tue Nov 15, 2011 9:33 pm    Post subject: Reply with quote
Everyone on TGO is an idiot. Razz
Does that mean you finally got bant?
PostPosted: Tue Nov 15, 2011 9:42 pm    Post subject: Reply with quote
Hehe... I was totally unable to draw a ban so I got bored and went on to more productive endeavors.
PostPosted: Tue Nov 15, 2011 9:50 pm    Post subject: Reply with quote
Depends.
Go WOT and see if you pull vacuum. If you do, it's a restriction.
My engine was restricted. Hense the 3.5" aluminum sewer pipe and giant cone filter. :_)
PostPosted: Wed Nov 16, 2011 9:08 am    Post subject: Reply with quote
Depends.
That's what I thought. Smile I remember trying that back in the day but I haven't in a while, it's datalog time!
PostPosted: Thu Nov 17, 2011 7:02 pm    Post subject: Reply with quote
So the whole list of to order stuff was ordered.
Remembered I need to get injector orings, but they are half the price locally. Plus still need to get a wp locally too.
PostPosted: Thu Nov 17, 2011 8:13 pm    Post subject: Reply with quote
Does a truck hat fit on your TB? My 97 tahoe is a vortec and the intake is fairly large. The clip setup they use is pretty wierd.
PostPosted: Sat Nov 19, 2011 11:08 pm    Post subject: Reply with quote
Just found an interesting tidbit about K&N filter media. It flows 6cfm per cubic inch of media(including folds) So all you need to do is measure those 2 little square filters and figure their area then x6.. thats how much air those will flow.
PostPosted: Sun Nov 20, 2011 5:51 am    Post subject: Reply with quote
I dont think the fliters are the restriction, its that hump over the radiator.
PostPosted: Sun Nov 20, 2011 7:13 am    Post subject: Reply with quote
Correct. Filters are like 6"x6" each. Across the radiator and into the snorkel it chokes down a lot. Then the snorkel gets wider on the other end... Rolling Eyes
PostPosted: Sun Nov 20, 2011 10:26 am    Post subject: Reply with quote
At 6x6 thats only 432cfm air flow through clean filters.
Page 2 of 2
