Lt1 cam in 305
Whiskeychick
1987 Pontiac GTA
PostPosted: Sat Nov 12, 2011 6:18 pm    Post subject: Lt1 cam in 305 Reply with quote
Anyone here running an lt1 cam in a newer third gen?
I know that the 87 and up can use the 94-97 lt1 ca. Want to know how well it woke upm if I'm right? Just wanted to know if anyone else had run this cam or not and how much it woke up the little 305.
Thinking it would be a cheap easy mod until I get my big engine rolling.
If anyone had done this, got any vids? Razz
PostPosted: Sat Nov 12, 2011 7:53 pm    Post subject: Reply with quote
I think Ian's old motor had an LT1 cam with the stealth ram.
The cam in my car is similar in specs to the LT1 cam, just a hair more aggresive on the ramps.
Based on both my car and Ians car, tuned right it should be good for 225-235 rwhp regarless of heads/intake used.
PostPosted: Sat Nov 12, 2011 9:08 pm    Post subject: Reply with quote
John has that same longblock with TPI on it in his Trans Am now and it seems like a nice little combo. The dyno numbers were crap due to running on seven cylinders, but that's John for you. Razz
I don't think it will ever hit 235 wheel horse with TPI, though. Ian only got 225 out of it with an HSR and them darn maths are against you when the engine is peaking out 700rpm before 5252.
PostPosted: Sat Nov 12, 2011 9:13 pm    Post subject: Reply with quote
There was more power in Ians motor, he was PIG rich when he did 225. I did the same HP with TBI, and a beat to hell motor that has some serious blow-by issues, and probably bad compression. In a healthy 305, with a good tune, I bet both mine and Ian's combos would made 235rwhp.
PostPosted: Sat Nov 12, 2011 10:34 pm    Post subject: Reply with quote
With the stealthram, LT1 cam and stock log manifolds I put down 226rwhp. With LT headers and some fumbling about in the tune* I put down 240(I think? It's been a bit, either 236-240rwhp). If you can tune there is still some power left on the table.
*All I did was smooth the tables and cut a bit of fuel as demonstrated by still almost pegging the WB the second time around.
That being said, I wouldn't waste your time unless you get the cam for CHEAP. I got mine for $10 on ls1tech.
PostPosted: Sat Nov 12, 2011 10:35 pm    Post subject: Reply with quote
Only reason I remember how much power there was the first time was because I beat Dew by 1hp. Very Happy
Whiskeychick
1987 Pontiac GTA
PostPosted: Sat Nov 12, 2011 10:46 pm    Post subject: Reply with quote
Yea I have been doing some reading since I posted. Looks like the lt1 if I can grab it cheap enough would be worth it.
Otherwise I think I'm kinda liking the 08-302-8 comp cam. Not sure if I want to spend that much on this engine though.
But the lt4 seems viable, or the zz4 if only a little big in the exhaust lift at .51. At least all cam s have the same lobe separation.
Don't suppose anyone has used any of them?
Thanks ian for details Smile
PostPosted: Sat Nov 12, 2011 11:27 pm    Post subject: Reply with quote
Of the comp cams grinds, I always liked the specs on 08-501-8. Problem is, the .495 lift on the exaust, that is going to require the valve guides cut down. But, if you cut them down, with 1.6 RR's that would be a healthy 305 cam. The one you picked out, is pretty close, but just a little less aggresive, it would probably be a pretty good fit with a 305, but will require probably quite a bit of computer tuning to run well.
PostPosted: Sat Nov 12, 2011 11:38 pm    Post subject: Reply with quote
Yeah, I got Ian's old 305 witt the LT1 cam in my '86 T/A. The LT1 cam seems to work well with a mostly stock tune (BTW, Aaron, those are not Ford pink top injectors. I found the bill of sale from when the original owner ordered them. I gotta change the injector constant.) Wish I had solid dyno numbers with the TPI intake on it, but like Aaron said, my number 7 plug wire got loose of its loom and melted on the header. Didn't find it until after dyno. Sad
PostPosted: Sun Nov 13, 2011 12:10 am    Post subject: Reply with quote
Buh? What the heck are they then?
PostPosted: Sun Nov 13, 2011 12:14 am    Post subject: Reply with quote
I'll have to check out the invoice again, but they were GMs for sure. Dude bought 'em off the internet and includedd the receipt with the rest of the paperwork he gave me with the car. Wink
PostPosted: Sun Nov 13, 2011 12:04 pm    Post subject: Reply with quote
What was CheezX running? His 305 put down 229hp the first year I dyno'd. I did 227 and Schultz did 230 with his l98.
PostPosted: Sun Nov 13, 2011 12:11 pm    Post subject: Reply with quote
My '87 TPI motor with an LT1 Cam and Edelbrock carb made a mere 180rwhp.
The nice thing about that cam, is the power curve was more of a flat line than a curve. So power all the time.
PostPosted: Sun Nov 13, 2011 2:52 pm    Post subject: Reply with quote
Ya was talking about that at lunch yesterday with some other crewbies. I actually think Cheezy put down the 230 and mine was 229. Of course there was a decent difference in torque but the later model LB9's did real good.
PostPosted: Sun Nov 13, 2011 3:38 pm    Post subject: Reply with quote
I think my 327 put a lot less torque then you 2 too. If I remember right it was only 266.
91camaro_rs
PostPosted: Sun Nov 13, 2011 5:44 pm    Post subject: Reply with quote
if yours guys' 305's put 225 to the wheels why is my 350 having troubles putting down 200? i replaced my transmission since i dynoed it which i would think would make a difference, but idk
PostPosted: Sun Nov 13, 2011 5:48 pm    Post subject: Reply with quote
I want to say he actually had a L98 cam. Its been a long time though, so my memory may be way off. The tuning, long tubes, and other little goodies he had going all worked well together on his motor.
91camaro_rs
PostPosted: Sun Nov 13, 2011 8:06 pm    Post subject: Reply with quote
i definatly need to get tuned, i just dont wanna do it myself cause i have no idea what im doing even tho i have all the equipmet
PostPosted: Sun Nov 13, 2011 8:17 pm    Post subject: Reply with quote
I thought Cheezy had the stock cam in his with the longtube headers and exhaust and then his own tune at that point. Could be wrong. Maybe I could message his old man and see if he could get us the answer Laughing
PostPosted: Sun Nov 13, 2011 9:09 pm    Post subject: Reply with quote
Gosh, old people and their feeble memories...
Very Happy
