A stupid proportioning valve question
PostPosted: Thu Sep 22, 2011 8:11 pm    Post subject: A stupid proportioning valve question Reply with quote
Why do people not run them in the passenger compartment?
Seems like the logical place to do it. Rear brake line runs right past the driver.
PostPosted: Thu Sep 22, 2011 8:44 pm    Post subject: Reply with quote
Because all the brake lines are on the outside of the car :O)
PostPosted: Thu Sep 22, 2011 8:48 pm    Post subject: Reply with quote
That seems like the easy part to fix. Laughing
PostPosted: Thu Sep 22, 2011 9:10 pm    Post subject: Re: A stupid proportioning valve question Reply with quote
The ones that do are road racers/drifters/motorsports guys that need/want to adjust the rear brakes on a fairly regular basis. The average joe gearhead is going to set it, test it, set it and then run it for the pretty much the life of the car.
PostPosted: Thu Sep 22, 2011 11:00 pm    Post subject: Reply with quote
Ian's right. Why add more knobs in places they're likely to be twiddled when they definitely do not need regular twiddling?
PostPosted: Fri Sep 23, 2011 5:23 am    Post subject: Reply with quote
Because I am insane and like to turn knobs and pull levers and whatnot. Very Happy
PostPosted: Fri Sep 23, 2011 10:34 am    Post subject: Reply with quote
Time for a Model A.
PostPosted: Fri Sep 23, 2011 11:07 am    Post subject: Reply with quote
Throttle and spark advance levers, baby! Laughing
IROCDave
PostPosted: Fri Sep 23, 2011 3:59 pm    Post subject: Reply with quote
Wait till till you have a wife and kids, you dont want to have anything they can control.
For instance, this can happen.
PostPosted: Fri Sep 23, 2011 4:02 pm    Post subject: Reply with quote
I'm not so sure about that Dave. We all know Aaron will never own a bmw 5 series. Very Happy
I cringe whenever I see that picture.
PostPosted: Fri Sep 23, 2011 4:50 pm    Post subject: Reply with quote
Looking at that picture is like watching someones limb get bent backwards. Hurts just thinking about it.
This is absolutely true. Were I to fall over to the Germanic side I would be looking for one with "the hot bit in the back" or if I went with a Beemer I would want a nice old 2002. Wink
Back to the topic at hand: I was thinking of attaching it down low between the drivers seat and the transmission tunnel. Out of sight of anyone not sitting in the drivers seat looking down past their leg.
I was also debating running two valves inline; one dial and one lever. That way I could fine-tune with the dial but still quickly slap the lever down if I suddenly decided I wanted no rears for any particular reason. Very Happy
Bear in mind that I am not running a center console, nor will there be any carpet going over the tunnel (just in the footwells).
PostPosted: Fri Sep 23, 2011 5:09 pm    Post subject: Reply with quote
lol Lever? That's what a line lock is for!
PostPosted: Fri Sep 23, 2011 5:12 pm    Post subject: Reply with quote
Doh! You're right, I forgot about running a line lock.
But I still like the idea of running the prop valve under the driver's seat.
PostPosted: Fri Sep 23, 2011 6:02 pm    Post subject: Reply with quote
Apparently we can't talk you out of it.
Aaron's gonna do what Aaron's gonna do.
Alternatively: What goes on in Aaron's car, stays in Aaron's car. Wink
PostPosted: Fri Sep 23, 2011 6:25 pm    Post subject: Reply with quote
If you really want to adjust them, why not get some balance-bar equiped pedals (or as chris would say..petals), then you can adjusta away till you realize that you don't drive hard enough long enough on the street to need to adjust your brake bias.
PostPosted: Fri Sep 23, 2011 11:49 pm    Post subject: Reply with quote
Yup! Wink
