Part 3: Lets get (back) down to business...
PostPosted: Thu Sep 22, 2011 7:44 am    Post subject: Reply with quote
Morgan is still making cars (high performance cars, mind you) with wooden framing behind the coachwork.
Wood is much lighter than steel and can be plenty strong if used correctly. The issue is longevity, cost and fire retardation.
PostPosted: Thu Sep 22, 2011 9:11 am    Post subject: Reply with quote
I look at this;
and think, "Yaaaaaaaaaayyyy!!"
IROCDave
PostPosted: Thu Sep 22, 2011 2:30 pm    Post subject: Reply with quote
Man thats a big job changing colors of paint. A couple of things that came to mind while looking at the pictures, Were the gaps between body panels / doors / hatch etc good? Also might want to paint your final coat around the gas tank fill plastic shroud. That would be a bitch to prep and paint later. You could leave it, but every time you fill up you will know what color the car used to be....
IROCDave
PostPosted: Thu Sep 22, 2011 2:45 pm    Post subject: Reply with quote
Oh, and dont think the poke at GM didnt go unnoticed Very Happy Maybe Ford should have stuck with wood...
http://www.raptorforumz.com/showthread.php?t=14208
I hadnt heard about this until last night. Adam Carolla mentioned it on the car show. He had a great line about it. The guy from thesmokingtire.com has one and was trying to say that the ten trucks with bent frames all hit something. Adam responded with " yea, they hit reality".
PostPosted: Thu Sep 22, 2011 5:37 pm    Post subject: Reply with quote
Not really. But not enough to bother me.
It is six screws to remove, and three of them are not even tightened. Laughing I will pull it out before I paint.
The whole thing will get bomb-canned or shot cheap with single-stage. As has been mentioned previously I am not an aesthetically picky person. On the contrary I do not want a nice car for fear of ruining it. I built this thing to beat fast cars, not to look pretty and sit still.
My mind is completely boggled by anyone who expects to buy a factory "performance" vehicle from a mainstream manufacturer. If you buy a new Camaro you need to immediately pull it into the shop and start cutting off the stupid horsecrap the engineers thought it needed.
If you buy a new Ford F-150 and flog it on the trail it will break. It's your fault for expecting engineers who build Ford Tauruses to be able to design a Trophy Truck. They can't do it. It's not their job. It's not what they do.
You need to build it right yourself, pay someone to build it right, or it will be built wrong. It's just that simple.
End of rant, start of building: Wink
Hatch:
All you damn kids laughed at me when I said I wanted a heater-delete hatch. Too rare you all said.
There are three thirdgens apiece at the Tumwater and Lakewood Pick-A joints. Three of them have the heater delete, three do not. One of the heater deletes was smashed, as were two of the heated units. One of the non-heater units was the aforementioned unit with the third brake light. However I found a non-light non-heat hatch on a 1990 Firebird in Tumwater yesterday. John and I went down today to grab it.
We started off by pulling the decklid off of Bananer:
...and dropping it onto John's primer-bombed Berli:
John's rusted hunk of a decklid was turned in at the yard for a core:
Then we went to the yard and pulled my new hatch:
...and installed the decklid I had previously pulled from that '87 Camaro in Lakewood. Hatch installation juice was critical to our success. Wink
...and dropped it onto the car. John obviously approves:
Decided I should probably do something about the yellow/bare steel combo we had going on.
Somehow I think I look like a hairy Mr. Burns in this picture. Squint
That's better (my priming job was much better than John's Razz):
More to come!
PostPosted: Thu Sep 22, 2011 5:49 pm    Post subject: Reply with quote
nice work dude, its coming along well!
-Donald
PostPosted: Thu Sep 22, 2011 6:34 pm    Post subject: Reply with quote
We should point out that we put the yellow deck lid on my car 'cause it is drilled for a spoiler. I could have drilled the holes myself, but my lid was already pretty rusted and this should be plug-n-play! Wink
PostPosted: Thu Sep 22, 2011 7:26 pm    Post subject: Reply with quote
Laughing @ 'hairy mr burns'!
Glad to see progress. Looking forward to following the build.
PostPosted: Thu Sep 22, 2011 7:46 pm    Post subject: Reply with quote
Dinner and more beer resulted in installation of additional parts.
Frame braces painted and installed:
Also some other crap I put under the hood while I was in there: Wink
PostPosted: Thu Sep 22, 2011 7:56 pm    Post subject: Reply with quote
Whats that dinky thing? a motorcycle engine? LOL Razz
PostPosted: Thu Sep 22, 2011 8:04 pm    Post subject: Reply with quote
Pretty much, yeah... LMAO
PostPosted: Thu Sep 22, 2011 9:45 pm    Post subject: Reply with quote
Ugh! That dirty engine is befouling your pristine engine bay!!! Laughing
PostPosted: Thu Sep 22, 2011 10:24 pm    Post subject: Reply with quote
You'll be able to smuggle a family of illegals between the front of the engine and the radiator! Laughing
PostPosted: Fri Sep 23, 2011 7:44 am    Post subject: Reply with quote
That engine looks really cool in there! Is the transmission already hooked up too? I'm looking forward to the overall results.
PostPosted: Fri Sep 23, 2011 8:00 am    Post subject: Reply with quote
What? That engine is totally clean. Well fairly clean.
Hopefully I'll at least be able to smuggled the hot and cold piping.
T5 is not installed in that picture. I am waiting on the clutch and flywheel to arrive. There is an older picture somewhere of the engine and transmission installed in the old chassis.
IROCDave
PostPosted: Fri Sep 23, 2011 3:49 pm    Post subject: Reply with quote
I like the non grid / heated hatch glass look. By the time they heat up enough to knock the ice off the coolant temp is already at 180+ degrees anyway. Besides that, who besides Ian drives their 3rd gens in the snow?
BTW, I was just giving you crap about the Raptor. Anyone who plans to go balls out offroading a production vehicle should expect something like this to happen.
Hell, I broke all but one leaf spring on a set of Rancho 4" lift leaf springs on my 74 Blazer going over a speed bump at 40 MPH. I beat the crap out of that thing and the one thing I took away from it was even aftermarket stuff breaks when jumping, power sliding over whoop de does at 50 MPH etc. To much mud = replacing the HEI distributor, carb and to many sever departure angles ripped the factory hitch off the frame. That hard to do on a SWB blazer. If the top was off the doors would pop open when going over whoops.
The frame never bent and stayed bent though.
PostPosted: Fri Sep 23, 2011 5:05 pm    Post subject: Reply with quote
Thanks. I am very partial to it. I was surprised by how many I found in the local yards.
I drove my IROC during the big ol' blizzard we had a few years back, but that was because it was the only running vehicle I owned. I have a nice Ford 4x4 for that kind of crappy stuff now. Wink
Exactly. You can't expect the people who built this piece of garbage:
...to be able to build you something that will get you this kind of action:
PostPosted: Fri Sep 23, 2011 5:30 pm    Post subject: Reply with quote
total photochop. Laughing
IROCDave
PostPosted: Fri Sep 23, 2011 6:09 pm    Post subject: Reply with quote
No wonder the fenders are missing Very Happy
PostPosted: Fri Sep 23, 2011 8:43 pm    Post subject: Reply with quote
Rolling Eyes Laughing
Front suspension is back under the car today.
Of course I had an ulterior motive for that; I needed my jackstands. Wink
Rear dropped
Ran into a bit of trouble though. Gonna have to hunt down a new set of rears:
Fronts coming off:
Then I got sidetracked by a new toy:
Hmm...
Sweet!
Anybody need anything at the Tumwater yard? I'll probably be down there at some point this weekend buying goddamned springs. Bashy Bashy
Page 2 of 3
