code 45- updated with datalog info-
Goto page 1, 2, 3  Next
PostPosted: Sun Sep 18, 2011 10:52 pm    Post subject: code 45- updated with datalog info- Reply with quote
Please help me with code 45! 1987 trans am. 305 tpi
code 45 is "Oxygen sensor rich"
i have replaced:
mass air flow sensor,
o2 sensor,
air filter,
whole exhaust(no cat anymore) headman hedders/dynomax catback,
coolant temp sensor(the one directly under intake and a temp sensor down below on pass side),
spark-plug wires(i have e3 spark plugs),
coil,
fuel filter,
all vacuum lines i could follow,
what else should i check or replace? i don't know where to look from here.
it is intermediate too, one minute it will idle perfect and then it will go crappy again
a little video of it in action Mad
http://www.youtube.com/watch?v=xz-uL6K_7J0
<iframe></iframe>
*in the middle I was holding it at about 800rmp, that wasn't the car itself
-Donald
PostPosted: Mon Sep 19, 2011 6:06 am    Post subject: Reply with quote
When you replaced the plugs did you read the old ones? If one or more of them was black you could have an injector stuck open.
*Edit: Wait a minute... I remember what you last question here was:
http://cascadecrew.org/phpBB2/viewtopic.php?t=8643
Pokey pokey
PostPosted: Mon Sep 19, 2011 10:49 am    Post subject: Reply with quote
Pokey pokey
i didnt recently replace the spark plugs, i bought those e3 ones a while back but i thought they should still be good
please dont hold that last thread against me! it was in the middle of the night and i was just trying to get it back together. since then i have welded in a bung up closer on the hedder and put a brand new o2 sensor in.
i did a few hours of research last night and most of the "code 45"
threads were left unanswered on tgo. i am going to check the charcoal canister today to see if its clogged or w/e. i also would like to check the fuel pressure but i havent figured out how to do that yet.
-Donald
IROCDave
PostPosted: Mon Sep 19, 2011 1:25 pm    Post subject: Reply with quote
Pull the plugs and see if they are wet, atleast on the drivers side. While you have them out, take all four, put them in a bag, walk outside the house and find the big gray thing. Toss them in it and buy a decent sent of plugs.
I have never been a fan of gimmicks and thos plugs are based off of an old gimmick. My brother brought a set over and was raving about them. Any one remember Spilt Fires? Atleast those were made in the US. E3's say China right on em and they look like it.
PostPosted: Mon Sep 19, 2011 2:18 pm    Post subject: Reply with quote
the big gray thing? the only gray thing outside my house is my dad's '99 firebird Wink lol we got green garbage cans here.
it ran fine when i first put them in. what brand would you reccommend?
-Donald
PostPosted: Mon Sep 19, 2011 4:50 pm    Post subject: Reply with quote
When I saw E3 I thought something similar but was keeping quiet. It may not be your problem though. All you need is a good copper core plug. Autolite, AC delco or my current favorite NGK. Anything more and I think you're wasting money. Now on a more modern motor that won't see a set of plugs but every 100k miles, then a good double platinum/iridium is the answer.
And why does the phrase "code 45" make me think cheap malt liquor?? Very Happy
izcain
9sec Club
PostPosted: Mon Sep 19, 2011 6:52 pm    Post subject: Reply with quote
I like NGK plugs they tend to be easier to read but that is maybe just me.
9.17 @ 148
PostPosted: Mon Sep 19, 2011 7:15 pm    Post subject: Reply with quote
NGK -> Autolite or AC Delco -> Gimmicky BS ----------------> Bosch Rolling Eyes
Just my two cents.
Dave is correct, you need to read plugs. If all the plugs are dark that means a general rich condition. If only one or a few are dark it means a cylinder-specific problem.
izcain
9sec Club
PostPosted: Mon Sep 19, 2011 7:20 pm    Post subject: Reply with quote
Do you have a diagnostic chart to go off of?
9.17 @ 148
izcain
9sec Club
PostPosted: Mon Sep 19, 2011 7:27 pm    Post subject: Reply with quote
Have you taken a fuel pressure reading?
Have you checked TPS voltage? Intermittent TPS can cause this.
Also people find that EMI or induced electrical "noise" has can cause this on the No. 453 ground circuit (Ignition system reference low). The additional pulses result in a higher then acual engine speed causing the ecu to throw more fuel at it then needed. Normally a goofy tachometer shows up as well though and that can be a telltale sign of this problem.
9.17 @ 148
PostPosted: Mon Sep 19, 2011 8:24 pm    Post subject: Reply with quote
Cracked reluctor wheel in the distributor perhaps? That will also cause extra injector pulses.
PostPosted: Mon Sep 19, 2011 10:09 pm    Post subject: Reply with quote
i'll start tomorrow by pulling some plugs and seeing what they are showing
i dont know what that is, but i am going to try to order a cable tomorrow so i can plug my laptop into my car
where is this ground you speak of?
could that of easily cracked when i tilted my engine back when replacing my transmission? i think i took the cap off but i"m not certain i did
-Donald
PostPosted: Mon Sep 19, 2011 10:11 pm    Post subject: Reply with quote
They usually just crack from rust and age.. and gm building them cheap. It's hard to see if they're cracked though without disassembling the entire distributor. Almost easier to slip a known good one in and see if its better.
PostPosted: Mon Sep 19, 2011 10:13 pm    Post subject: Reply with quote
oh thats lame. i guess i'll check a few easier things first!
-Donald
PostPosted: Mon Sep 19, 2011 10:46 pm    Post subject: Reply with quote
i would like to add that the engine idles perfect once the engine light comes on.
when the engine light comes on, done the ecm:
a)go into a safe mode (figuratively-i don't know how it works)
or
B) stop trying to fix the fuel mixture
I'm just trying to get some information to understand my problem a bit more
-Donald
PostPosted: Tue Sep 20, 2011 8:06 am    Post subject: Reply with quote
SES light on means limp home mode.
Sounds like you have a sensor fubar if it runs crappy before the light comes on. Start unplugging sensors when the light is off.
Autolite spark plugs were the best plug I could buy for my 330hp 350.
Those cheap 1 wire o2's are crap.
Check the plugs first.
PostPosted: Tue Sep 20, 2011 4:42 pm    Post subject: Reply with quote
As Paul says.. sensor if it runs poor with the light off, and better with it on. The reluctor I was talking about would run poor both ways, so probably not it.
PostPosted: Tue Sep 20, 2011 10:30 pm    Post subject: Reply with quote
alright thanks guys, i now have some stuff to tinker with!
edit:
is http://obd1.com/ the cheapest place to buy the cable to datalog?
would this be an easy problem to diagnose if i was able to datalog?
-Donald
PostPosted: Wed Sep 21, 2011 3:50 am    Post subject: Reply with quote
EGR stuck open?
PostPosted: Wed Oct 05, 2011 5:27 pm    Post subject: Reply with quote
ok i got some datalog info. i dont really know what i am looking at besides that i noticed my "blm" is at like 108 when i read it was suppose to be like 128.
can someone look over my datalog file? i used datamaster because i couldnt get tuner pro to datalog.
quick screen shot
-Donald
Page 1 of 3
