Posted: Sun Sep 04, 2011 1:53 pm Post subject: |
Very cool Al! Looking good! _________________ 84 Camaro Z28 - LS1/T56
Posted: Sun Sep 04, 2011 2:22 pm Post subject: |
| aaron_sK wrote: | Not pumping air into a cat that needs it will clog it up.
Aaron sorry to correct ya man... but the air is an add on. Most "univeral" cats come with an air tube. If you don't need it, you cap it off. Air helps the cold catalyzation process. No further. Wont clog any faster.
Clean motor AL. Glad you got it running acceptably and that starter worked out well for ya! _________________ A redline a day keeps the carbon away! |
Posted: Sun Sep 04, 2011 2:32 pm Post subject: |
My understanding of older-school converters with the tube that it was needed to keep them from staying too cold and getting clogged.
However, I stand corrected, Paul.
Funny thing about all of mine, they all somehow fall off the car and end up at the scrapyard.  |
Posted: Sun Sep 04, 2011 3:30 pm Post subject: |
I still have the stock cat (with y-pipe) sitting in the garage. Current one is a universal 3" "high flow" Walker cat from West Bay (now NAPA).
What's left to do?
Larger injectors, but first a higher volume fuel pump. The pump will go in the tank I picked up from Aaron which has a nice sealing surface on the filler neck for the cap. These 454 injectors will fit my TBI-220 throttle body, but they're $100 apiece.
http://www.fuelinjector.citymaker.com/catalog/item/5448589/5392046.htm
Using this table, I crossed the two part numbers to a TBI-220 application, my injectors are p/n 5235206, these are p/n 1784304.
http://www.fuelinjector.citymaker.com/Rochester_TBI.html
This piece is $130 plus $50 core and includes the same injectors, FPR, gasket - basically the top half of the TBI unit.
http://www.injectorwarehouse.com/tbi/tb124-2a.htm
I have some worn out steel fuel lines that I'm thinking of converting to braided line, just have a shop cut the middle section out, keep the fittings and replace the steel tubing with braided hose. |
Posted: Sun Sep 04, 2011 4:53 pm Post subject: |
That's awesome al! How much more power does it feel like it has?i bet that thing screams now! _________________ 1983 Z-28 5.7 LT1, T56, Headman headers, BW 9 Bolt Posi Disc, WS6 suspension
Posted: Sun Sep 04, 2011 6:22 pm Post subject: |
| iansane wrote: | That's exciting. I can't wait to see what she puts down. |
I'll have it up your way a week from tomorrow. I have a bowling night after work and won't be in the normal vanpool. I might be able to drop by and show it off to ya  |
Dan Johnson Member
Joined: 26 Feb 2010 Posts: 29 Location: Poulsbo, WA. 98370
Posted: Sun Sep 04, 2011 6:45 pm Post subject: |
Al, I'll buy any left over stock parts you dont want. Dan _________________ DJ |
Posted: Sun Sep 04, 2011 7:04 pm Post subject: |
Not much left, Dan. Most went with the old motor, but I do have some of the exhaust and emissions stuff; log manifolds with air tubes, air pump, diverter valve & solenoids, catalytic converter and y-pipe.
Other stuff from this and previous projects; trans cross-member, front brake calipers (cast iron), and e-brake lever. |
Dan Johnson Member
Posted: Sun Sep 04, 2011 8:12 pm Post subject: |
what the heck I can never pass up good stock parts! Dan _________________ DJ |
Posted: Sun Sep 04, 2011 8:39 pm Post subject: |
| Can I bring some out tomorrow sometime? I have a 9:00am alignment appointment at Firestone, after that I'm pretty much open all day. |
Dan Johnson Member
Posted: Sun Sep 04, 2011 8:45 pm Post subject: |
I'm putting a clutch in the 92 tomorow, be home till around 2:00. Dan _________________ DJ |
Posted: Sun Sep 04, 2011 8:52 pm Post subject: |
| Cool, that gives me a little time to get some of it together after the front end alignment. Noon sound good? |
Dan Johnson Member
Posted: Sun Sep 04, 2011 8:56 pm Post subject: |
yep _________________ DJ |
Posted: Mon Sep 05, 2011 6:32 pm Post subject: |
I finished up putting the console back together today and find that the spring for the ash tray lid has broken through the hole that it's anchored in. Looks like I'm in need of another 5-speed console cover (just saw Skyler is looking for one too).
Went to get the front end aligned this morning and find that a new driver side ball joint is in order. Somewhere, somehow, the cotter pin had come out and the castle nut had backed off a bit. While sitting in the driveway, it seized itself to the ball joint stud and won't turn without rotating the stud. It's not coming off without either splitting the nut or cutting it off. |
Posted: Mon Sep 05, 2011 7:31 pm Post subject: |
That's awesome Al! Glad you got it sorted out!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Mon Sep 05, 2011 9:10 pm Post subject: |
| 83Z28BlackBetty wrote: | | That's awesome al! How much more power does it feel like it has?i bet that thing screams now! |
I didn't see this earlier. Definitely more than the 305. Without trying, I can break the tires loose, earlier today, I broke them loose going into second gear at about 30mph and did a short fishtail  |
Posted: Mon Sep 05, 2011 10:26 pm Post subject: |
that's awesome to hear! I'm right on your heals in the swap phase, i just sent my pcm to be reprogrammed so i can finally start this thing up!
Dan Johnson Member
Posted: Wed Sep 07, 2011 6:49 pm Post subject: |
what was the bike on the roof for this morning, backup? Dan _________________ DJ |
Posted: Wed Sep 07, 2011 6:52 pm Post subject: |
I packed the bike to load onto the van that I take to work from Kingston to Bothell. I rode from Bothell to Kingston with a ferry trip in between
You must have been in the 2nd gen beside me at the light on Viking Way - I forgot you had that one  |
