turbo_jimi Member
Posted: Sun Aug 21, 2011 8:04 pm Post subject: carpet installed, now heater doesnt work |
The black n gray combo doesnt look too bad, but now i need to trouble shoot my heater fan and left rear speaker _________________
Posted: Sun Aug 21, 2011 8:11 pm Post subject: |
Speaker wires come up one side and then cross over at the b-pillar. I forget which way they go, but fortunately I have a car with no carpet so I can check for you.
Heater is a molded triple-wire unit, blue yellow and orange, that comes from the HVAC control and heads through the firewall on the passenger side. |
turbo_jimi Member
Posted: Sun Aug 21, 2011 8:18 pm Post subject: |
I probably pulled a wire loose, need to clean the controls anyways. _________________
turbo_jimi Member
Posted: Mon Aug 29, 2011 8:17 pm Post subject: |
Got the fan working again...changed the fuse and cleaned the connections and is started working again...still don't have "high" but the next one up works and that's where it's staying.  _________________
Posted: Mon Aug 29, 2011 8:22 pm Post subject: |
Maybe the high speed relay. All other speeds go through the resistor network. _________________ 92 Camaro
Posted: Mon Aug 29, 2011 8:23 pm Post subject: |
| Is this an A/C car, or a factory delete car? Only A/C cars got the relay, and it only works if you kept your A/C harness when you deleted the rest of it. |
turbo_jimi Member
Posted: Mon Aug 29, 2011 8:25 pm Post subject: |
It was an A/C car that I converted years ago and I have the relay...a cube that the wires run through. _________________
Posted: Mon Aug 29, 2011 8:27 pm Post subject: |
| Try pulling the relay off and jumping the harness with a lead. |
turbo_jimi Member
Posted: Mon Aug 29, 2011 8:34 pm Post subject: |
I'll try that tomorrow. Thanks. _________________
turbo_jimi Member
Posted: Wed Sep 21, 2011 6:26 pm Post subject: |
Figured the out Left Rear speaker...blown. And it was fairly new. Ended up swapping it out for a really old Sony 3-way that originally came in John's (RSFreak) 83 Z28 around '94 or '95 when he bought it. Works great for my musical needs.  _________________
