Wolffy Member
Posted: Thu Apr 21, 2005 7:23 am Post subject: soft brakes |
ok heres my saga, i swapped to 4 wheel disc & since then the brakes are soft ( i havent driven the car since last fall, so im not completly sure, but i know they werent this soft)
last night we bleed all 4 lines & they are still soft
we did not bleed the MC thou, im thinking that might be it, i do have a new one i can put on
the booster is getting vacuum, i checked that cause i also put on the HSR
pumping them first doesnt really seem to make much diff, that i can tell
if i broke the lines from the MC to the prop valve, would i need to bleed the MC, as i recall i shouldnt have to, but its been awhile
i am still using the prop valve from the drum rear end, as the replacement that i got yesterday (from a 4 wheel disc brake car), 2 of the fittings are fine thread instead of course.
any ideas/suggestions
thanxs |
BigDaddyVu 12sec Club
Posted: Thu Apr 21, 2005 10:55 pm Post subject: |
| Hey dude i told you to check out the Vacum booster i had the same problem with my TA and you can also adjust the rod inside between the master and booster. |
kurfbird Member
Posted: Fri Apr 22, 2005 6:54 pm Post subject: Properational Valve |
I would find the right Properational valve. Then bleed and see if you still have the same problem.
Having wrong parts on brakes is not the way to go. Just my 2 cents.
Kurfbird _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
