Freakin rodents
PostPosted: Sat Jun 08, 2013 1:24 pm    Post subject: Freakin rodents Reply with quote
Just got done removing a huge nest from behind the dash of the bird. Stinky little buggers. Car was fine at cows but when I went to work on my headlight, I opened the door and omg. I figured one had died in the heater. So I took the heater box apart. Good news.. that was clean inside. Then I removed the drivers side hush panel and found a stinky wad of firewall insulation. Febrezed the hell out of the car and have the windows open now. Think I'll need some carpet fresh or something even yet. Not sure if damage from a cat is worse then this.
So if I keel over in the next 24hrs it was probably Hanta virus.
MrMike98
PostPosted: Sat Jun 08, 2013 3:54 pm    Post subject: Reply with quote
last month i developed a bad engine running issue in my santa fe- opened the hood and most of the hood insulation was missing-
removed engine cover and found my missing insulation and a chewed up #3 plug wire.....
that was the good news
bad news is i had to remove the damn intake manifold to replace plugs or wires!! nice design...
and i drive it daily -so they were very busy that night....
PostPosted: Thu Jun 13, 2013 3:56 pm    Post subject: Reply with quote
See Brandon, those Pontiacs are good for something,,,, low income mouse house!!
