Posted: Mon May 06, 2013 2:36 pm Post subject: how to make window go up |
| So I have some different doors I am going to put on. But harness is cut. I need the window up so I can unplug all the connectors of cut harness and plug in my connectors. |
Posted: Mon May 06, 2013 4:15 pm Post subject: |
Apply 12v and ground to the window motor.
If it goes down instead hook it up the other way around. _________________ 84 Camaro Z28 - LS1/T56
Posted: Mon May 06, 2013 5:03 pm Post subject: |
| Ok. To the actual motor? I was hooking to.the wires |
Posted: Mon May 06, 2013 5:25 pm Post subject: |
Either should work. The wires are directly connected to the motor.  _________________ 84 Camaro Z28 - LS1/T56
