flea Member
Posted: Sun Mar 31, 2013 10:02 am Post subject: Valve guide removal. |
I need the top secret recipe for removing the valve guides from a 1929 Model A.
This would no doubt be easier if everything wasn't the same shade of 84 year old rust, and if I could actually see individual parts.
Can they be tapped out from the top down? Is there anything holding them in place other than 84 year old rust? is there a keeper rusted in there someplace?
Valves and springs are out, just need the guides evicted. _________________ Killing mailboxes since 2009 |
charlie6178 Member
Posted: Mon Apr 01, 2013 4:54 pm Post subject: |
if it's original and unmolested it should have a 2 piece valve guide in it, and they can be a nightmare to get out! do you have new guides for it?? and or new valves??? if you are doing new valves and you have new guides you can cut the tip of the valve off, weld a nut to the seal grove of the guide, and pull on it with a heavy slide hammer. if not there is an atattchment for a snap on 3 jaw to pull the guides with that too. i have done them both ways, both work. _________________ 1992 Camaro 1LE Z28 |
flea Member
Posted: Tue Apr 02, 2013 6:18 am Post subject: |
Cool, that's exactly what I was looking for. They do just slide out though correct? I was thinking about a piece of pipe or steel rod to tap in pushing them out from the top downward.
It will be stripped down to the block, resurfaced, checked for cracks and rebuilt. _________________ Killing mailboxes since 2009 |
Posted: Tue Apr 02, 2013 9:32 am Post subject: |
If you dont mind, post some pictures of the whole project. Ive only seen them as complete trash buckets, or fully fixed. _________________ 2008 GMC Z71
Posted: Tue Apr 02, 2013 10:16 am Post subject: |
| 91RSVert wrote: | | If you dont mind, post some pictures of the whole project. |
I don't think that this is the project you are hoping it is!  |
Posted: Tue Apr 02, 2013 11:06 am Post subject: |
Just back into it woth your car _________________ A redline a day keeps the carbon away! |
Posted: Tue Apr 02, 2013 11:16 am Post subject: |
| Twilightoptics wrote: | | Just back into it woth your car |
flea Member
Posted: Tue Apr 02, 2013 11:31 am Post subject: |
Run over one little mailbox...
Besides that's how I was gonna get the cam out. _________________ Killing mailboxes since 2009
flea Member
Posted: Tue Apr 02, 2013 11:33 am Post subject: |
But yes I can post a pic...promise its not what you're thinking
And hopefully it will look like this soon.
See, not what you thought. _________________ Killing mailboxes since 2009 |
Posted: Wed Apr 03, 2013 6:40 am Post subject: |
Your correct, I thought you were restoring a car. I saw someone post on here a few months back they had a really old car. Thought it was you.
So your using a old car engine in a kit airplane? Or am I even off on that? |
flea Member
Posted: Wed Apr 03, 2013 10:08 am Post subject: |
Only off in so far as its not a kit. It's plans built. They first flew in 31 I think, using model A for power. So there it is. _________________ Killing mailboxes since 2009 |
charlie6178 Member
Posted: Wed Apr 03, 2013 2:19 pm Post subject: |
| flea wrote: | Cool, that's exactly what I was looking for. They do just slide out though correct? I was thinking about a piece of pipe or steel rod to tap in pushing them out from the top downward.
It will be stripped down to the block, resurfaced, checked for cracks and rebuilt. |
they do push out. they are in there pretty good tho. some of them have to come out the top tho. some have a snap ring, and or flat washer built onto them! snap on makes valve guide drivers for an air hammer if you end up cutting the tip of the valve off. after the guides are replaced you are going to have to have the seats cut. if it were me, i would let whatever machine shop you're going to use to rebuild it, handle the guides, and seat cut. _________________ 1992 Camaro 1LE Z28 |
Posted: Wed Apr 03, 2013 3:33 pm Post subject: |
Finding disappointment in the fact that none of his projects have yet resulted in a horrible crash-and-explosion-related death, flea has now decided to up the ante.  |
Posted: Wed Apr 03, 2013 4:01 pm Post subject: |
| flea wrote: | | Only off in so far as its not a kit. It's plans built. They first flew in 31 I think, using model A for power. So there it is. |
So you buy the plans/wood, and cut to fit yourself then? |
flea Member
Posted: Wed Apr 03, 2013 9:08 pm Post subject: |
| 91RSVert wrote: | | flea wrote: | | Only off in so far as its not a kit. It's plans built. They first flew in 31 I think, using model A for power. So there it is. |
Yep that's about it. Pretty simple structure, the main bits are 1x1 hemlock (spruce would be better) sheeted with 1/8 mahogany. Wings are, or will be, 1/4x1/2" spruce ribs and 1"x 5" spruce spars milled to the correct final dimensions and taper. _________________ Killing mailboxes since 2009 |
flea Member
Posted: Wed Apr 03, 2013 9:09 pm Post subject: |
| aaron_sK wrote: | Finding disappointment in the fact that none of his projects have yet resulted in a horrible crash-and-explosion-related death, flea has now decided to up the ante.  |
Well recklessness hasn't killed me yet. Imagine what I can do with a little caution. _________________ Killing mailboxes since 2009 |
Posted: Wed Apr 03, 2013 9:13 pm Post subject: |
I was not previously aware of the hemlock. That choice does not say "caution" to me.
Hem splits and blows out and smells like poo when you cut it.  |
Posted: Wed Apr 03, 2013 10:02 pm Post subject: |
You are a brave man! I would never fly in something I built!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Thu Apr 04, 2013 2:37 am Post subject: |
| RSFreak wrote: | You are a brave man! I would never fly in something I built!  |  |
flea Member
Posted: Thu Apr 04, 2013 4:13 am Post subject: |
| aaron_sK wrote: | I was not previously aware of the hemlock. That choice does not say "caution" to me.
http://www.sportair.com/articles/Aircraft%20Wood%20-%20Part%20One.html
Hemlock can split if you're not careful. But as far as aircraft use it is acceptable. It is a little heavier than Sitka Spruce, but also a little stronger. The real key here, and Aaron you will appreciate this, is that it is MUCH cheaper. A little selective shopping around at the local lumber yard, and it can be had for about a buck a foot. 1x1 and this place - THE place, it is 2.35 plus 35% for lengths over ten feet.
http://www.aircraftspruce.com/catalog/wppages/capstrip.php
I needed 4 pieces at 16 feet and a handful of shorter pieces plus the shipping.
Say what you will about my laid back and somewhat goofy sense of humor etc. but there is a learning curve here, and I am not doing anything on this project without spending all the time I need to do the learning. _________________ Killing mailboxes since 2009 |
