ChrisB Member
Posted: Thu Mar 07, 2013 4:07 pm Post subject: Just a reminder! |
CHECK The OBVIOUS first
Car developed a bit of a rough idle, and had some part throttle hesitation around 3k.
I was going to dive into it this weekend and see if I could figure her out. Popped the hood to check the oil and noticed the plug wires resting on the exhaust manifold.
Burned the wires. PO didn't use the factory retainers or any method of keeping plug wires sorted out.
I know this is kind of a useless thread, but everyone of is guilty of overlooking the obvious at some point or another. So a helpful reminder never hurts.  _________________ 91 Z28 |
turbo_jimi Member
Posted: Thu Mar 07, 2013 4:21 pm Post subject: |
I know how that goes...had one recently doing that. _________________
Posted: Thu Mar 07, 2013 5:47 pm Post subject: |
It happens to the best of us. I've overlooked the simple things more often than I'd like to admit. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Thu Mar 07, 2013 6:29 pm Post subject: |
I seem to recall an instance or two of people running on the dyno with only 7 cylinders firing due to similar issues.  _________________ 84 Camaro Z28 - LS1/T56
Posted: Thu Mar 07, 2013 7:24 pm Post subject: |
After I put my headers on, I got 2 of the wires on the passenger side switched. Couldn't figure it out, even after checking the firing order several times. It took another set of eyes and ears to find the problem. _________________ 92 Camaro
Posted: Thu Mar 07, 2013 8:12 pm Post subject: |
Booster line on the back of the tpi plenum got me a few times. Always a damn maf car too. _________________ A redline a day keeps the carbon away! |
83Z28BlackBetty Bam-Ba-Lam
Posted: Thu Mar 07, 2013 11:47 pm Post subject: |
After I got the lt1 swap running I found out i forgot to plug a 1/2 in pipe plug hole in the manifold under the throttle body, then I wondered why it was idling so high... Doh! _________________ 1983 Z-28 5.7 LT1, T56, Headman headers, BW 9 Bolt Posi Disc, WS6 suspension
Posted: Sat Mar 09, 2013 10:30 am Post subject: |
I think the worst one I was guilty of was crossing 4-6 wires on the old "hello kitty" car, and wondering why the hell the thing ran so badly and chasing my tail on the ignition box wiring for about two days.
:duh: |
