jchaussee Member
Posted: Sat Feb 23, 2013 2:09 am Post subject: welder |
| I want to buy a good priced welder. What things do I look for on cl. I can only go wire feed. I am decent on thicker steel, bit want to learn how to do thon gauge and aluminium |
Posted: Sat Feb 23, 2013 5:38 am Post subject: |
Some of the welders now have plastic gears and feeders. Get one that has metal ones.
I have a miller welder. I could go get you model number if you wish. I have had it 3-4 years, light useage. No problems at all with it. _________________ 2008 GMC Z71
jchaussee Member
Posted: Sat Feb 23, 2013 12:45 pm Post subject: |
| From what I read miller and Lincoln are the good brands. My problem is that I know so little that when looking on craigslist I get frustrated. |
Posted: Sat Feb 23, 2013 5:36 pm Post subject: |
Mine is a 140 if that helps you.
I have done sheetmetal work, and some frame work. Did both fairly well, I think the downfall was the users skill
I do recall thinking the miller and lincoln were the few that still had metal items inside. |
Posted: Sat Feb 23, 2013 9:41 pm Post subject: |
I've had a Lincoln 135 gas for 5 years maybe? I have no idea what I'm doing but it's worked great for me!  _________________
jchaussee Member
Posted: Sat Feb 23, 2013 10:32 pm Post subject: |
| You do different materials? |
Posted: Sat Feb 23, 2013 11:27 pm Post subject: |
........ standard wire feed joins ferrous metals only. _________________ A redline a day keeps the carbon away! |
jchaussee Member
Posted: Sat Feb 23, 2013 11:38 pm Post subject: |
| What would you suggest as a decent budget welder for a novice Paul? |
Posted: Sun Feb 24, 2013 8:10 am Post subject: |
No such thing. Get a 110v miller, lincoln, esab, o r thermalarc or waste your money. They all do the same thing. Those do it better and last longer and you pay for it. _________________ A redline a day keeps the carbon away! |
jchaussee Member
Posted: Sun Feb 24, 2013 9:23 am Post subject: |
| 110 over 220?? |
Posted: Sun Feb 24, 2013 9:26 am Post subject: |
If you're a beginner and you don't understand the brands/styles/etc you shouldn't be touching a 220v welder. _________________ A redline a day keeps the carbon away! |
jchaussee Member
Posted: Sun Feb 24, 2013 9:37 am Post subject: |
| Ok. Thanks for info. |
Posted: Sun Feb 24, 2013 9:44 am Post subject: |
You don't need 220 until you start welding 3/8"+ and need perfect penetration. So, nothing on a car. _________________ A redline a day keeps the carbon away! |
jchaussee Member
Posted: Sun Feb 24, 2013 9:53 am Post subject: |
| 3/8?wow. So basically most people don't need 220. Another reason I was asking is because I see a lot of 220 ones on cl. |
Posted: Sun Feb 24, 2013 6:28 pm Post subject: |
| My 140 says it will do 1/4 metal. So I would agree with the 220 being overkill for automotive world. |
