nonsensekid20 Member
Posted: Mon Feb 04, 2013 8:27 pm Post subject: Gauge problems |
| Alright so I need a quick answer here. The speedometer and gas gauge don't work in my car. I just installed LED bulbs and so far they work. BUT, the 2nd bulb in from the left that lights up the right side of the speedo and the gas gauge turns off when you turn the ignition off, but works when you have it on ACC. Also, before I had a problem where I could set the cluster in, and the gas gauge would work with the key on IGN, then I would turn the lights on and all the gauges would drop and turn off. WTF?! HELP. |
