Odd problem.....
BluFbdy
PostPosted: Sat Jan 19, 2013 12:32 pm    Post subject: Odd problem..... Reply with quote
So i got a spare gauge cluster from luke with the tach fix done to it and after some drinking last night i decided to do some tinkering with it.
Luke gave it to me because he said the odometer spins backwards... I talked to aaron about it briefly and he said it may be gear alignment but after popping it open the gears arent out of alignment, i did however find a cable that goes from the motor down to a printed circuit board with a 4 pin plug, no identifying marks on it to show which way it plugs in and it will go either way. Do you think its possible that plug was put it backwards? Causing the odometer to spin in reverse? I cant find any info on the subject and idk where to find a diagram that would explain this in detail
On a side not the odometer now reflects my proper mileage Laughing
Any ideas?
PostPosted: Sat Jan 19, 2013 12:51 pm    Post subject: Reply with quote
Makes sense.
BluFbdy
PostPosted: Sat Jan 19, 2013 1:16 pm    Post subject: Reply with quote
Now here's the issue with drinking whole doing this... Idk which was it was before lol Idk if trial and error would screw anything up
PostPosted: Sat Jan 19, 2013 1:24 pm    Post subject: Reply with quote
Only one way to find out!!
BluFbdy
PostPosted: Sat Jan 19, 2013 2:33 pm    Post subject: Reply with quote
This is true, what confuses me though is the odometer is on a stepper setup, how could it run backwards? To get the mileage right I had to skip the left number forward because it had just enough wiggle room to do so and then run it forward by hand but I couldn't rotate it backwards at all, obviously I'm not gonna crank on the thing too hard
PostPosted: Sat Jan 19, 2013 9:05 pm    Post subject: Reply with quote
Every time I see a 90-92 cluster it's having some sort of horrible problem. You should have kept the old dash. Laughing
BluFbdy
PostPosted: Sat Jan 19, 2013 9:15 pm    Post subject: Reply with quote
Then I would have 90 million wiring issues lol I'm gonna pull my current cluster out of the dash and copy it, the plug actually looks like its supposed to be soldered in, good job gm with cold joints Laughing
