Front spring rubber isolator
PostPosted: Fri Dec 21, 2012 3:43 pm    Post subject: Front spring rubber isolator Reply with quote
Before I put my front springs back in I might as well replace the rubber that goes on top of spring.
Question: Is there a better design out there other than the rubber ring on the stock suspension? Specifically wondering if a hard cup is available, kind of like the rear suspension. It will be a lot easier to line up and stay in place.
PostPosted: Fri Dec 21, 2012 6:51 pm    Post subject: Reply with quote
If your rubber is salvageable just tape it on there with electrical tape.
If the rubber is shot I have used a slit heater hose in the past.
PostPosted: Fri Dec 21, 2012 7:01 pm    Post subject: Reply with quote
Lmao.. I can just see Jon using either of those methods...
PostPosted: Fri Dec 21, 2012 7:12 pm    Post subject: Reply with quote
I was going to suggest throwing the isolator in the garbage like a normal person would, but I figured that might be ab it much for him. Razz
PostPosted: Fri Dec 21, 2012 8:12 pm    Post subject: Reply with quote
Why bother with the slit in the heater hose? The hose slipped right over my springs...
PostPosted: Fri Dec 21, 2012 10:30 pm    Post subject: Reply with quote
This is going to blow your minds but I think slipping heater hose over a coil is genius.
Thanks for the idea.
PostPosted: Fri Dec 21, 2012 10:59 pm    Post subject: Reply with quote
If you really want to be hardcore about it you could get some oil line from a local hydraulic shop. Much thicker and stronger than heater hose.
PostPosted: Sun Dec 23, 2012 1:26 pm    Post subject: Reply with quote
I yanked my isolators the first chance I had. They just introduce slop in the suspension.
