Posted: Fri Dec 21, 2012 3:43 pm Post subject: Front spring rubber isolator |
Before I put my front springs back in I might as well replace the rubber that goes on top of spring.
Question: Is there a better design out there other than the rubber ring on the stock suspension? Specifically wondering if a hard cup is available, kind of like the rear suspension. It will be a lot easier to line up and stay in place. |
Posted: Fri Dec 21, 2012 6:51 pm Post subject: |
If your rubber is salvageable just tape it on there with electrical tape.
If the rubber is shot I have used a slit heater hose in the past. |
Posted: Fri Dec 21, 2012 7:01 pm Post subject: |
| Lmao.. I can just see Jon using either of those methods... |
Posted: Fri Dec 21, 2012 7:12 pm Post subject: |
I was going to suggest throwing the isolator in the garbage like a normal person would, but I figured that might be ab it much for him.  |
Posted: Fri Dec 21, 2012 8:12 pm Post subject: |
Why bother with the slit in the heater hose? The hose slipped right over my springs... _________________ 92 Camaro
Posted: Fri Dec 21, 2012 10:30 pm Post subject: |
This is going to blow your minds but I think slipping heater hose over a coil is genius.
Thanks for the idea. |
Posted: Fri Dec 21, 2012 10:59 pm Post subject: |
| If you really want to be hardcore about it you could get some oil line from a local hydraulic shop. Much thicker and stronger than heater hose. |
Posted: Sun Dec 23, 2012 1:26 pm Post subject: |
| I yanked my isolators the first chance I had. They just introduce slop in the suspension. |
